VAG-COM Discussion
Bentley manual, adaption & coding?
Old Feb 15, 2012 | 08:05 PM
Quattro4me2006's Avatar
Default Bentley manual, adaption & coding?
Hi - I just got the Bentley Repair manual on DVD for my 06 A6, and I've been looking it over, but haven't found any coding or adaption information in it. Am I missing something, or is there a separate manual which shows this detail?
I'd really like to get rid of the seat belt chime, etc., but even with VCDS I don't understand the process well enough to attempt it. Any advice for a newbie?
Old Feb 15, 2012 | 08:33 PM
javicadena's Avatar
Search this forum, you tube is also very helpful. Additionally, the FAQ section of the Ross-tech website is quite useful
Old Feb 16, 2012 | 04:39 PM
Uwe@Ross-Tech.com's Avatar
Banned
Post up an Auto-Scan so we can see exactly what control modules are installed in your car and how they are configured. If you need help doing that, it's explained in great detail in this video:
http://www.youtube.com/watch?v=RCBt6d42-Fc
-Uwe-
Old Feb 17, 2012 | 07:04 AM
zulujams's Avatar
Some setting changes are easy check boxes, others require you to have some basic understanding of bits and then change a specific bit between 0 and 1. If you're not comfortable with it, post your location and request help. Quite a few people with VCDS experience are willing to give advice and even meet you to teach or just make the changes you want.
Old Feb 17, 2012 | 07:39 PM
Hey, guys - thank you for your input. I've appended the auto scan below.
I've read through a lot of stuff, and I think I'm starting to understand coding & adaption more. Having said that, I'm interested in doing a few tweaks - some of which I understand, others that I haven't seen in VCDS' label files yet.
For starters, I'll be disabling the seat belt chime and I've already got the windows and sunroof setup with the remote. If it is possible, I would also like to enable:
1. Digital speed reading in the cluster (including for cruise control, like in the '08 or '09)
2. Needle sweep at startup
3. Hidden "green" menu in MMI
4. Tire pressures in MMI - in PSI (I've never seen this listed)
5. Battery level in MMI
6. Flashing brake light under emergency braking
7. Is it possible to enable use of the Xenon headlights for the coming home function?
8. Adjustment of the automatic headlight sunrise/dusk sensitivity
If any or all of these are possible, would long coding be needed to enable them?
Sorry to dump all these questions at once - thank you in advance for any suggestions you can give!
Friday,10,February,2012,16:38:05:30075
VCDS Version: Release 11.11.2
Data version: 20120126
Chassis Type: 4F0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
********* 53 55 56 61 62 65 67 72 76 77
VIN: WAUDL74F76N037085** Mileage: 131350km/81617miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine******* Labels: None
** Part No SW: 4F0 910 560 E*** HW: 4F0 907 559
** Component: 4.2L V8/5V***** G** 0010*
** Revision: --H01---*** Serial number:**************
** Coding: 0007772
** Shop #: WSC 02335 785 00200
** VCID: 244DF0C6E7C0DE3
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans******* Labels: 09L-927-760.lbl
** Part No SW: 4F1 910 156 Q*** HW: 09L 927 156 A
** Component: AG6 09L 4,2 MPI USA 0020*
** Revision: --H01---*** Serial number:******* 4042425
** Coding: 0000002
** VCID: 3261069EAD34403
Address 03: ABS Brakes******* Labels: 4F0-910-517.lbl
** Part No SW: 4F0 910 517 L*** HW: 4F0 614 517 L
** Component: ESP 8.0 quattro H03 0090*
** Revision: 00000000*** Serial number: 00000000000000
** Coding: 0021352
** VCID: 2D5B15E2B40A1FB
Address 05: Acc/Start Auth.******* Labels: 4F0-910-852.clb
** Part No SW: 4F0 910 852**** HW: 4F0 905 852 B
** Component: FBSAUDIC6 ELV** H30 0180*
** Revision: 30070501*** Serial number: 10600300188925
** Coding: 0000015
** Shop #: WSC 20205 444 59528
** VCID: E3CF33DA224E19B
** Part No: 4F0 910 131 L
** Component: FBSAUDIC6 EZS** H44 0070
** Part No: 4F0 910 335
** Component: FBSAUDIC6 KSG** H26 0080
** Part No: 4F0 910 220 G
** Component: FBSAUDIC6 IDG** H44 0060
1 Fault Found:
00193 - Right Rear Door Handle Touch Sensor (G418)
*********** 011 - Open Circuit - Intermittent
************ Freeze Frame:
******************* Fault Status: 00111011
******************* Fault Priority: 3
******************* Fault Frequency: 95
******************* Reset counter: 70
******************* Mileage: 116895 km
******************* Time Indication: 0
******************* Date: 2011.08.03
******************* Time: 09:03:47
Address 07: Control Head******* Labels: 4F0-910-7xx-07-H.lbl
** Part No SW: 4F0 910 732 Q*** HW: 4E0 035 729
** Component: Interfacebox*** H43 4610*
** Revision: 00000000*** Serial number: 303FJ057501935
** Coding: 0000003
** Shop #: WSC 42013 444 53529
** VCID: 31630992A8327BB
** Part No: 4F0 910 609 E
** Component: Bedienteil MMIC6H07 0050
Address 08: Auto HVAC******* Labels: 4F0-910-043.lbl
** Part No SW: 4F0 910 043**** HW: 4F1 820 043 S
** Component: KLIMABETAETIGUNGH12 0160*
** Revision: 00000027*** Serial number: 00000000153853
** Coding: 0008232
** VCID: DBBF0B3A1A3E21B
Address 09: Cent. Elect.******* Labels: 4F0-910-279.lbl
** Part No SW: 4F0 910 279 A*** HW: 4F0 907 279 A
** Component: ILM Fahrer***** H14 0080*
** Revision: 00000000*** Serial number: 4F0907279****
** Coding: 0113123
** VCID: 2757E7CA96F635B
** Subsystem 1 - Part No: 4F1 910 113** Labels: 1KX-955-119.CLB
** Component: Wischer AudiC6* H05 0150*
** Coding: 00062736
** Shop #: WSC 02335*
** Subsystem 2 - Part No: 4E0 910 557** Labels: 8K0-955-559.CLB
** Component: REGENLICHTSENSORH10 0050*
** Coding: 00141886
1 Fault Found:
01800 - Light Switch (E1)
*********** 008 - Implausible Signal - Intermittent
******************* Fault Status: 00101000
******************* Fault Priority: 2
******************* Fault Frequency: 4
******************* Reset counter: 46
******************* Mileage: 130816 km
******************* Date: 2012.02.03
******************* Time: 07:26:00
Address 0E: Media Player 1******* Labels: 4E0-910-111.lbl
** Part No SW: 4E0 910 111 F*** HW: 4E0 035 111 A
** Component: CD-Changer***** H44 0470*
** Revision: 00000000*** Serial number: AUZ5ZBE7184162
** Shop #: WSC 00000 000 00000
** VCID: 1C3DC826DFB0E63
Address 0F: Digital Radio******* Labels: 4E0-910-593-SIR.lbl
** Part No SW: 4E0 910 593 D*** HW: 4E0 035 593
** Component: SDAR SIRIUS**** H04 0670*
** Revision: 00000000*** Serial number: AUZ4Z7E4009153
** VCID: 2855E4F69BE83A3
Address 15: Airbags******* Labels: 4F0-910-655-8R.lbl
** Part No SW: 4F0 910 655 F*** HW: 4F0 959 655 A
** Component: 66 AIRBAG AUDI8RH29 0300*
** Revision: 11H29000*** Serial number: 00359D091KU4*
** Coding: 0013878
** Shop #: WSC 20205 444 84600
** VCID: 2A511EFE85E4083
** Part No: 4F0 910 339 A
** Component: BF-Gewichtsens. H02 0050
1 Fault Found:
02511 - Control Module for Seat Occupied Recognition (J706)
*********** 014 - Defective - Intermittent - MIL ON
Address 16: Steering wheel******* Labels: 4F0-910-549.lbl
** Part No SW: 4F0 910 549**** HW: 4F0 953 549 A
** Component: Lenksäulenmodul H07 0230*
** Revision: 00H07000*** Serial number: 90022051580264
** Coding: 0012041
** VCID: E6C92ACED17C6C3
** Part No: XXXXXXXXXXX
** Component: Lenkradmodul*** H07 0080
Address 17: Instruments******* Labels: 4F0-910-xxx-17.lbl
** Part No SW: 4F0 910 930 A*** HW: 4F0 920 980 N
** Component: KOMBIINSTR. M73 H15 0630*
** Revision: 01000000*** Serial number: 4PY513L65****
** Coding: 2129263
** Shop #: WSC 20209 444 999999
** VCID: 2143F9D2F8D2CBB
Address 19: CAN Gateway******* Labels: 4F0-910-468.lbl
** Part No SW: 4F0 910 468 A*** HW: 4F0 907 468 D
** Component: Gateway******** H10 0060*
** Revision: 10********* Serial number: 120080560980BC
** Coding: ECFE73CD1B7904
Address 36: Seat Mem. Drvr******* Labels: None
** Part No SW: 4F0 910 760**** HW: 4F0 959 760
** Component: Sitzmemory FS** H04 0050*
** Revision: 00000000*** Serial number: 00000000896400
** Coding: 0082954
** VCID: E1C339D238520BB
Address 37: Navigation******* Labels: 4E0-910-88x-37.lbl
** Part No SW: 4E0 910 887 N*** HW: 4E0 919 887 C
** Component: MNS US********* H44 0740*
** Revision: 00000000*** Serial number: 355FX057548184
** VCID: 387534B64B48AA3
Address 42: Door Elect, Driver******* Labels: 4F0-910-793-42.lbl
** Part No SW: 4F0 910 793 B*** HW: 4F0 959 793 B
** Component: TSG FA********* H11 0040*
** Revision: 00-00000***
** Coding: 0051947
** VCID: 2953E1F280E203B
Address 46: Central Conv.******* Labels: 4F0-910-289.lbl
** Part No SW: 4F0 910 289 G*** HW: 4F0 907 289 G
** Component: Komfortgeraet** H19 0140*
** Revision: 01400019*** Serial number: 01004877920000
** Coding: 4619453
** Shop #: WSC 42013 444 64598
** VCID: 2E5912EEB90C643
** Part No: 1K0 951 605 C
** Component: LIN BACKUP HORN H03 1301
Address 47: Sound System******* Labels: 4F0-910-223-BO.lbl
** Part No SW: 4F0 910 223 J*** HW: 4F0 035 223 G
** Component: DSP-High C6**** H09 0240*
** Revision: PROD_01**** Serial number: 00000000790310
** Coding: 0000026
** VCID: 254BEDC2ECFA27B
Address 4F: Centr. Electr. II******* Labels: 4F0-910-280.lbl
** Part No SW: 4F0 910 280**** HW: 4F0 907 280 B
** Component: ILM Beifahrer** H10 0080*
** Revision:************ Serial number: 00000000002379
** Coding: 0012114
** VCID: DEB9022E092C343
Address 52: Door Elect, Pass.******* Labels: 4F0-910-793-52.lbl
** Part No SW: 4F0 910 793 B*** HW: 4F0 959 792 B
** Component: TSG BF********* H11 0040*
** Coding: 0051947
Address 53: Parking Brake******* Labels: 4F0-910-801.clb
** Part No SW: 4F0 910 801**** HW: 4F0 907 801
** Component: EPB* C63C0030** H03 0030*
** Revision: C63C0030***
** Coding: 0006022
** Shop #: WSC 02334 785 00200
** VCID: DDBB0522042A2FB
Address 55: Xenon Range******* Labels: 4F0-910-357.lbl
** Part No SW: 4F0 910 357 F*** HW: 4F0 907 357 F
** Component: AFS 1********** H01 0020*
** Revision: 00000001*** Serial number:**************
** Coding: 0000016
** Shop #: WSC 20213 444 53529
** Part No: 4F0 941 329 B
** Component: AFS-Modul links H02 0020
** Component: AFS-Modul rechtsH02 0020
Address 56: Radio******* Labels: 4E0-910-541.lbl
** Part No SW: 4E0 910 541 T*** HW: 4F0 035 541 B
** Component: TUNER EU/US/RDW H42 0630*
** Revision: 00000000*** Serial number: 394F1057559496
** Coding: 0000002
Address 61: Battery Regul.******* Labels: 4F0-910-181.lbl
** Part No SW: 4F0 910 181 E*** HW: 4F0 915 181 A
** Component: ENERGIEMANAGER* H12 0490*
** Revision: 00000000*** Serial number: 00000000054822
** Shop #: WSC 20205 444 53766
** VCID: 234FF3DAE2CED9B
** Subsystem 1 - Part No: 4F0 915 105 D
** Component: von VA0* 390825P03W******
** Coding: 344630393135313035442056413033393038323550303357
** Shop #: WSC 20213 444 64598
Address 62: Door, Rear Left******* Labels: 4F0-910-795.lbl
** Part No SW: 4F0 910 795**** HW: 4F0 959 795
** Component: TSG HL********* H11 0030*
** Coding: 0051754
** VCID: E9D321F2C06243B
Address 65: Tire Pressure******* Labels: 4F0-910-273-BA.lbl
** Part No SW: 4F0 910 273**** HW: 4F0 907 273
** Component: Reifendruck 3** H04 0080*
** Revision: 00040080*** Serial number: 00000900006328
** Coding: 0062422
** VCID: E0C53CD63358023
1 Fault Found:
02214 - Tire Pressure Warning
*********** 000 -* -* - Intermittent
******************* Fault Status: 00100000
******************* Fault Priority: 1
******************* Fault Frequency: 1
******************* Reset counter: 40
******************* Mileage: 0 km
******************* (no units): 0.0
******************* Temperature: 40.0°C
******************* Error Code: 1
*********************** Not Recogn.
Address 67: Voice Control******* Labels: 4E0-910-75x-67.lbl
** Part No SW: 4E0 910 754 Q*** HW: 4E0 035 753 A
** Component: SDS 3501 US**** H45 0630*
** Revision: 00000000*** Serial number: 00000506150153
** Shop #: WSC 12336 024 394758
** VCID: 346D008657204E3
Address 72: Door, Rear Right******* Labels: 4F0-910-795.lbl
** Part No SW: 4F0 910 795**** HW: 4F0 959 794
** Component: TSG HR********* H11 0030*
** Coding: 0051754
Address 76: Park Assist******* Labels: 4Fx-910-283.lbl
** Part No SW: 4F0 910 283 B*** HW: 4F0 919 283 B
** Component: Parkhilfe 4-Kan H09 0020*
** Revision: 00H09000*** Serial number: 11720514002379
** Coding: 0201206
Address 77: Telephone******* Labels: 4E0-910-336.lbl
** Part No SW: 4F0 910 336 H*** HW: 4E0 862 335
** Component: Handyvorb2***** H11 1130*
** Revision: 00000000*** Serial number: 00000007502980
** Coding: 0010900
End** ---------------------------------------------------------------------
Old Feb 20, 2012 | 03:34 PM
Banned
[Select]
[17-Instruments]
[Coding-07]
Change it from 2129263 to 2129203
-Uwe-
StuttgartStan
Oct 22, 2012 01:21 AM
isleblue65
10
Apr 16, 2011 09:27 PM
03_AR_CO
Audi allroad
Mar 5, 2009 08:31 PM
couperacer2
Apr 17, 2006 06:02 PM
AbnormallyAspirated
Jan 23, 2002 07:45 AM
