VAG-COM Discussion
code interpretation
Old Aug 11, 2003 | 07:07 PM
1/4 scale's Avatar
Default code interpretation
I'm getting a dtc fault of 64764: unknown: reason [64764] [sporadic] on 01 engine module. Anyone know what this means?
Also, is there a complete source of 5-digit dtcs somewhere? I've seen the R. Bentley link but it seems to not have all the codes I'm experiencing. And, could someone explain what the difference is between these 5-digit dtcs and the PXXXX type dtcs. Sorry if this has been hashed over but I can't seem to get a straight answer via searching (also I'm just ramping up to speed on digital diagnostic systems).
Thanks.
Old Aug 11, 2003 | 07:18 PM
Uwe@Ross-Tech.com's Avatar
Banned
Default DTC 64764 is undefined.
And there's no PXXXX code equivalent. If your ECU is chipped, talk to your chip-tuner.
5-Digit codes are native VAG codes. PXXXX codes are defined by the SAE. Since VAG-COM uses the native VAG protocols just like the dealer's tool, it receives native VAG codes from the car. If there's an SAE equivalent P-code number, current versions of VAG-COM will give that to you as well.
-Uwe-
Old Aug 11, 2003 | 08:06 PM
1/4 scale's Avatar
Default Thanks Uwe
I've been also getting dtcs like 01371 (defined as: "alarm via door contact switch driver's side") without the PXXXX SAE equivlents. I guess this means it is only reading native VAG codes. The car is chip, hence no PXXXX readings for 64764 (?). Thanks again.
skl1
VAG-COM Discussion
Jun 12, 2006 05:24 AM
TheMike
Jun 8, 2006 12:02 PM
bjaro5187
Jan 6, 2005 06:42 PM
Imola_Tip_Soul-Ja
Jul 11, 2004 12:07 AM
klsandiego
Jan 15, 2004 02:56 AM
