Error Codes Help:Warm Up Catalyst (Both Banks) Efficiency Below Threshold
The CEL came back after about 80 miles (mostly highway).
From Searching the archives, I am seeing posts that it could be either the O2 Sensors or the Cats.
Or, could this be caused by something else?
Anyone know for sure how to tell what it is? I just passed 70K miles when I got the first code. I've read, in other posts, about a 80K Mile Emissions waranty??? Is this true? Would it only cover the cats, or would it cover O2s also?
Obviously, the onlyway the car is going to a dealer is if the work is covered by a waranty, otherwise I'll take it to an Indy shop.
Any information you might have on this would be very helpful.
Thanks!
Codes Below:
2 DTC codes found
16805 - Warm Up Catalyst: Bank 1:
Efficiency Below Threshold :
P0421
00035 35-10 - - Sporadic
16815 - Warm Up Catalyst: Bank 2:
P0431
00035 35-00 -
So, the question is....have you monitored blocks 41 and 42 to check the condition of your rear O2 heaters. Also, a basic setting check on block 36 should show you the condition of the sensors themselves.
And finally, what are the conversion values shown in blocks 46 and 47, field #3 when you run a cat diagnosis?
