Fault Codes Found!
idea!?
I STFA, and lots of people have 00858 fault code, but no one posted the solution, so please help me out here... thanks for any input!
Address 08: Auto HVAC Labels: 8E0-820-043.LBL
Part No: 8E0 820 043 L
Component: A4 Klimaautomat 1016
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
01810 - Actuating Motor for Temperature Flap; Right (V159)
41-10 - Blocked or No Voltage - Intermittent
Address 37: Navigation Labels: 8E0-035-192-RNSE.LBL
Part No SW: 8E0 035 192 D HW: 8E0 035 192 D
Component: RNS-E US3 H72 0150
Coding: 0301111
Shop #: WSC 36510
2 Faults Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 24
Reset counter: 88
Freeze Frame:
Mileage: 655350 km
Count: 2406
Clock: 20:00
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 10
Reset counter: 4
Do you have a new radio/CD installed to your car afterwards, i.e. it originally did not have CD. The above article says:
"On older or non-cd cars, the aerial amp/switcher wasn't present and so when you upgrade, there is no way to make the connections that the head unit is expecting, hence the fault."
