VAG-COM Discussion
Hardware question - which cable is needed
Old Dec 10, 2007 | 05:03 PM
TristanP's Avatar
Default Hardware question - which cable is needed
Friend of mine has a TT (1st gen, maybe MY2000) and a 2006 or 2007 Jetta. Which VAG-COM cable would work on both? I was reading on the site and it all seems very confusing. I have the shareware version and serial OBDTool cable for my '01 A4 - will I be able to clear codes on his Jetta? Thanks.
Old Dec 11, 2007 | 05:06 AM
Andy@Ross-Tech's Avatar
Banned
Default 2006/2007 Jetta uses CAN-Bus diagnostics so a genuine Ross-Tech CAN-Bus Interface is required.
HEX-COM+CAN (if you have a 9-male-pin Serial Port) or the HEX-USB+CAN (if you only have a USB port) would be needed for use with both your TT and with the Jetta.<ul><li><a href="http://www.ross-tech.com/Merchant2/merchant.mvc?Screen=CTGY&amp;Category_Code=VAGCOM" >http://www.ross-tech.com/Merchant2/merchant.mvc?Screen=CTGY&amp;Category_Code=VAGCOM</a</li></ul>
Old Dec 11, 2007 | 05:38 AM
TristanP's Avatar
Thanks
DynomiteTT
VAG-COM Discussion
Feb 2, 2007 01:22 PM
cdog12
Feb 6, 2006 04:47 PM
Miah_S4Avant
VAG-COM Discussion
Jun 22, 2005 05:16 AM
A4Alien
Apr 19, 2002 08:08 AM
bustertt
May 22, 2001 04:11 PM
