VAG-COM Discussion
Key & Locking Module Problems
Old Sep 4, 2005 | 12:21 AM
pixeljoy's Avatar
New Member
Default Key & Locking Module Problems
Just to preface, the rear-left lock never has worked consistently by remote or by driver-side switch. Whenever it failed to work in the past, I would just manually push it down.
Later, all of my locks started behaving erratically with the remote. Sometimes they would work, other times not. The alarm would not arm itself unless I pressed lock on remote several times. Same when unlocking/disarming. After replacing remote battery, same thing, with the 00955 code popping up continually after being cleared. I figured it was just a remote issue, so started using the key to manually lock/unlock doors. I still had to turn the key twice to get the alarm to arm.
This seemed to do the trick until one day the key got stuck. I was a little too forceful and broke the lock in trying to get the key loose. Now my car seems possessed. The windows and locks go up and down at random times with the ignition on. With the ignition off, the windows always roll down and stay down and the car unlocks itself.
When locking the doors from driver-side switch, the driver-side lock pops back up again. This also happens if I manually push it down, though I have gotten it to stay down for at least a few minutes. Ultimately, it will unlock itself again with the rest of the locks. This was the rear-left lock behavior in the past.
Obviously I will need to replace the driver-side lock I busted, but does anyone have any ideas on what may have been causing the lock problems before I busted the lock. The window behavior really has me scratching my head. It's like that vw car noise music commercial, but in a nightmare.
Please help! TIA
VAG-COM Version: Release 504.1-D Stuff
Address 46: Central Conv.
Controller: 3B0 959 797 AB
Component: Zentral-SG Komfort V45
Coding: 04096
Shop #: WSC 05311
7 Faults Found:
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
01330 - Central Control Module for Central Convenience (J393)
49-10 - No Communications - Intermittent
00960 - Switch for Central Locking; Driver Side (F59)
29-00 - Short to Ground
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-10 - Implausible Signal - Intermittent
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
00930 - Locking Module for Central Locking; Rear Left (F222)
27-00 - Implausible Signal
00931 - Locking Module for Central Locking; Rear Right (F223)
Old Sep 5, 2005 | 12:23 AM
pixeljoy's Avatar
New Member
Default Re: Key & Locking Module Problems
Looks like I found a repair and the culprit.
http://www.taligentx.com/passat/maintenance/doorlockmechanism/
Cracked solder joints or bad microswitches in Locking Mechanism.
Farb
Jan 27, 2009 10:34 AM
qtroCUB
10
Jun 24, 2006 08:30 AM
ahaiceman
Dec 22, 2005 12:08 PM
Neo1130
Oct 12, 2005 05:54 PM
sethhirschel
Oct 27, 2004 12:10 PM
