VAG-COM Discussion
Long Code Helper
Old Dec 21, 2010 | 04:48 PM
fhpski's Avatar
Default Long Code Helper
When I first purchased my Vag Com Cable and used it to program the newly installed trailer hitch module. I had the long code help box in the coding of the module. But now I do not have the assistance of this important tool. Why did it disappear with the new software upgrades.
Old Jan 3, 2011 | 09:42 AM
fhpski's Avatar
Wow! No answers to this question about the software and Vag Com.
Old Jan 3, 2011 | 04:13 PM
Uwe@Ross-Tech.com's Avatar
Banned
We don't intentionally remove features, but sometimes we may goof up in terms of part numbers and such which are needed to identify systems. Please post up an Auto-Scan so we can see exactly what part numbers the modules installed in your vehicle have.
-Uwe-
Old Jan 4, 2011 | 05:30 AM
fhpski's Avatar
Thanks Uwe
Here is the scan:
Tuesday,21,December,2010,15:01:15:59817
VCDS Version: Release 10.6.3
Data version: 20101206
Chassis Type: 4L0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 3C 42 46 47 4F
52 55 56 61 62 65 67 69 6C 6D 6F 72 76 77
VIN: WA1BY74L67D087687 Mileage: 163870km/101824miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (BHK) Labels: 03H-906-032-BLV.lbl
Part No SW: 03H 906 032 BG HW: 03H 906 032 G
Component: Q7 3.6-FSI-LEV2 G 1634
Revision: 5CH05--- Serial number:
Coding: 0001175
Shop #: WSC 31414 790 00001
VCID: 68D4681622F5
5 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 3
Mileage: 162422 km
Time Indication: 0
Date: 2010.12.04
Time: 11:14:35
Freeze Frame:
RPM: 1647 /min
Load: 31.0 %
Speed: 21.0 km/h
Temperature: 77.0°C
Temperature: 38.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.097 V
000769 - Cylinder 1: Misfire Detected
P0301 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 162422 km
Time Indication: 0
Date: 2010.12.04
Time: 11:14:48
Freeze Frame:
RPM: 1644 /min
Load: 22.0 %
Speed: 32.0 km/h
Temperature: 78.0°C
Temperature: 30.0°C
Voltage: 14.097 V
000773 - Cylinder 5: Misfire Detected
P0305 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Mileage: 162422 km
Time Indication: 0
Date: 2010.12.04
Time: 11:14:48
Freeze Frame:
RPM: 1795 /min
Load: 38.0 %
Speed: 20.0 km/h
Temperature: 81.0°C
Temperature: 36.0°C
Voltage: 14.224 V
000772 - Cylinder 4: Misfire Detected
P0304 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Mileage: 162422 km
Time Indication: 0
Date: 2010.12.04
Time: 11:14:48
Freeze Frame:
RPM: 1795 /min
Load: 38.0 %
Speed: 20.0 km/h
Temperature: 81.0°C
Temperature: 36.0°C
Voltage: 14.224 V
000774 - Cylinder 6: Misfire Detected
P0306 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 162701 km
Time Indication: 0
Date: 2010.12.08
Time: 19:22:22
Freeze Frame:
RPM: 1795 /min
Load: 38.0 %
Speed: 20.0 km/h
Temperature: 81.0°C
Temperature: 36.0°C
Voltage: 14.224 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: None
Part No SW: 4L0 910 156 C HW: 0AT 927 156
Component: AG6 0AT 3,6 FSI USA 0010
Revision: --H01--- Serial number: 4018703
Coding: 0000002
VCID: 29522D12F97F
No fault code found.
Address 03: ABS Brakes Labels: 4L0-910-517.lbl
Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
Component: ESP ALLRAD MK25E1 0130
Revision: 00H22001
Coding: 0033809
VCID: 28542816E275
Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100679240
Coding: 0000135
Shop #: WSC 05164 444 82780
VCID: E3CEFF3A5BD3
Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0060
1 Fault Found:
02764 - Access/Start Authorization Switch (E408)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 162434 km
Time Indication: 0
Date: 2010.12.04
Time: 19:01:32
Address 07: Control Head Labels: 4L0-910-7xx-07-H.lbl
Part No SW: 4L0 910 731 P HW: 4E0 035 729 A
Component: Interfacebox H43 4140
Revision: 00000000 Serial number: 354BX077517992
Coding: 0002003
VCID: 356AF16225C7
Part No: 4L0 910 609
Component: E0380 BedienteilH01 0060
Address 08: Auto HVAC Labels: None
Part No SW: 4L0 910 043 HW: 4L0 820 043 F
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---012 Serial number: 00000030030158
Coding: 0524326
VCID: E1C2F53241CF
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0014123
VCID: 3162C572D1AF
Part No: 4L1 910 113
Component: Wischer AU716 H12 0080
Coding: 00064792
Shop #: WSC 31414
Part No: 4E0 910 557 A
Component: REGENLICHTSENSORH13 0090
Coding: 00150059
Shop #: WSC 31414
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4L0 910 110 A HW: 4L0 035 110
Component: MP3-Changer H43 0350
Revision: 00043000 Serial number: AUZ5ZBG1040339
Shop #: WSC 00000 000 00000
VCID: 1D3A09C2BD37
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 H HW: 4E0 035 593 D
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7G0044933
VCID: 2C5CD406F68D
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH41 0230
Revision: 05H41000 Serial number: 0038QD053WRV
Coding: 0014131
VCID: 2B5ED71AF383
Part No: 4L0 910 339
Component: BF-Gewichtsens. H02 0020
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90054070330171
Coding: 0002042
VCID: E6C8E62EA8E1
Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4L0 920 980 H
Component: KOMBIINSTR. M73 H18 0170
Revision: 00200000 Serial number: 5HH39RL27
Coding: 2641208
VCID: 234E3F3A9B53
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468 A
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0800D07122815E
Coding: F7D7FE77347A02
VCID: ECDC9406B60D
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4L0 959 760
Component: Sitzmemory FS H01 0100
Revision: 00000000 Serial number: 00000000896401
Coding: 0082954
VCID: E1C2F53241CF
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 L
Component: MNS US H48 1100
Revision: 00000000 Serial number: 313BN077517267
VCID: 3874F85632D5
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 B HW: 4L0 907 566 A
Component: J0769_SWA_MasterH07 0070
Revision: 00H07000 Serial number: 6PZ 009 014-00
Coding: 0000001
VCID: 2D5AD902CD97
Part No: 4L0 910 568 B
Component: J0770_SWA_Slave_H06 0070
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0130
Revision: 00000000 Serial number: E‚D
Coding: 0051915
VCID: 2F66C30AC79B
Address 46: Central Conv. Labels: 4L0-910-289.lbl
Part No SW: 4L0 910 289 D HW: 4L0 907 289 A
Component: Komfortgeraet H05 0020
Revision: 0020 --- Serial number: 01033360140000
Coding: 7370781
VCID: 3162C572D1AF
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Address 47: Sound System Labels: 4L0-910-223-BO.lbl
Part No SW: 4L0 910 223 G HW: 4L0 035 223 D
Component: DSP-High AU716 H03 0150
Revision: PROD_01 Serial number: 00000000017957
Coding: 0000026
VCID: 28542816E275
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000042834
Coding: 0012001
VCID: DEB8CECE70B1
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0130
Revision: 00000000 Serial number: '%G
Coding: 0051915
VCID: 2F66C30AC79B
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000021
VCID: 29522D12F97F
Part No: 7L6 941 329 A
Component: AFS-Modul links H06 0002
Component: AFS-Modul rechtsH06 0002
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 388B0077592974
Coding: 0000002
VCID: 2E58DE0EC091
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4L0 910 181 HW: 4L0 915 181
Component: J0644 BEM H12 0530
Revision: -------- Serial number: 00000000069226
VCID: E4CCFC265EDD
Part No: 4F0 915 105 D
Component: von VA0 2702150829
Coding: 344630393135313035442056413032373032313530383239
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0051722
VCID: 3162C572D1AF
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000900041726
Coding: 0062424
VCID: 22403A3E8449
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000701260307
Shop #: WSC 12336 024 394758
VCID: 346CCC662EBD
Address 69: Trailer Labels: 4E0-910-383.lbl
Part No SW: 4E0 910 383 C HW: 4E0 907 383 C
Component: ANHAENGERELEKTR 004 0060
Coding: 0000002
VCID: 244C3C269E5D
Address 6C: Back-up Cam. Labels: 4L0-910-441.lbl
Part No SW: 4L0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J7141MA
Coding: 1010101
VCID: 244C3C269E5D
1 Fault Found:
03006 - Back-up Camera System not calibrated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 236
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 B
Component: ValeoHeckdeckel H21 0280
Revision: --H21001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: ECDC9406B60D
Part No: 4L0 910 946
Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 002480196-----
Coding: 0000009
VCID: 2648262EE861
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0050
Coding: 0051722
VCID: 3162C572D1AF
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06230702100338
Coding: 0231246
VCID: 27562B2AEF6B
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 E HW: 4E0 862 335
Component: Handyvorb2 H16 0950
Revision: 00000000 Serial number: 00000007565008
Coding: 0010900
VCID: 254A21229567
End ---------------------------------------------------------------------
Old Jan 4, 2011 | 03:29 PM
Banned
Coding: 0000002
Your trailer module does not use Long Coding. It uses regular old "short" coding. Hence I am rather puzzled by your statememt that it "had the long code help box in the coding of the module" in a previous version. In fact, I find it downright implausible. ;-)
On that particular module, if you go to coding and wait a few seconds, a help balloon with a coding chart should show up. That chart should contain the following:
Trailer (J345) Coding
00000?x: Trailer Hitch
0 = Trailer Hitch without Swivel Function
1 = Trailer Hitch with automatic Swivel Function
2 = Trailer Hitch with mechanical Swivel Function
00000x?: Country
1 = Rest of World (RoW)
2 = North America (USA/Canada)
-Uwe-
Old Jan 5, 2011 | 05:21 AM
fhpski's Avatar
Uwe
Thanks for the insight.
RAD2
VAG-COM Discussion
Jan 10, 2011 04:05 PM
Cabal_san
A4 (B8 Platform) Discussion
Sep 10, 2009 08:39 AM
Audone
Sep 21, 2004 11:36 AM
Steve Trac, Sec 303
Jan 13, 2003 01:25 PM
zardozrdr
9
Dec 18, 2002 06:03 PM
