P1338 Camshaft sensor code error - voltage to sensor is 11.3v - is that too high?
I've used my multimeter to look at the resistance between each of the 3 sensor unit wires (looking into the sensor, not the ECU) and even on the highest (20M) range there is no reading but maybe this is correct?
Any help appreciated. I've got to go into the engine in a few weeks to replace the front crank oil seal so will look at this problem at the same time.
