VAG-COM Discussion
is it possible?
Old Nov 9, 2009 | 09:39 AM
xewax's Avatar
Default is it possible?
Hello,
When the car (audi A6 tdi) is idle the rpm seems too low, is it possible to increase it using vag com or any other software?
thanks in advance
Old Nov 9, 2009 | 09:40 AM
xewax's Avatar
not the audi in the signature
Old Nov 9, 2009 | 10:53 AM
Uwe@Ross-Tech.com's Avatar
Banned
"Audi A6 TDI" could be a number of different engined and model years from the mid 1990's to current. Wanna narrow this down a little?
-Uwe-
Old Nov 9, 2009 | 12:01 PM
xewax's Avatar
-Uwe-
Its A6 before 96. the old one. engine 2.5 tdi.
Old Nov 9, 2009 | 07:19 PM
Banned
Post some scan data please.
-Uwe-
Old Nov 15, 2009 | 12:47 PM
xewax's Avatar
Update: Audi A6 2002 1.9 tdi
Scan data: Dont pay attention to all the errors. This car has not been started fot 3 months.
VAG-COM Version: Release 409.1-US
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56,76
Address 01: Engine
Controller: 038 906 019 GF
Component: 1,9l R4 EDC G000SG 1434
Coding: 00002
Shop #: WSC 02325
WAUZZZ4B82N005253 AUZ5Z0A4160133
No fault code found.
Readiness: N/A
Address 03: ABS Brakes
Controller: 4B0 614 517 G
Component: ABS/ESP front 1328
Coding: 06275
Shop #: WSC 00011
Address 08: Auto HVAC
Controller: 4B0 820 043 AB
Component: A6-Klimavollautomat 0104
Coding: 00103
Shop #: WSC 02325
3 Faults Found:
00797 - Sunlight Photo Sensor (G107)
31-00 - Open or Short to Ground
01592 - Air Quality Sensor (G238)
37-00 - Faulty
01206 - Signal for Duration of Ignition: OFF
27-00 - Implausible Signal
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 4B0 920 900 Q
Component: KOMBI+WEGFAHRS. M73 D06
Coding: 00872
Shop #: WSC 03794
XXXXXXXXXXXXXXXXX
Address 35: Centr. Locks
Controller: 4B0 962 258 K
Component: Zentralverrieg.,DWA D35
Coding: 06763
Shop #: WSC 03212
9 Faults Found:
00668 - Supply Voltage Terminal 30
07-10 - Signal too Low - Intermittent
01559 - Drivers Door
58-10 - Can't Lock - Intermittent
01560 - Passenger Door
59-00 - Can't Unlock
60-00 - Won't Safe
01561 - Left Rear Door
60-00 - Won't Safe
61-00 - Won't De-Safe
01482 - Motors for Central Locking
29-10 - Short to Ground - Intermittent
01134 - Alarm Horn (H12)
49-10 - No Communications - Intermittent
76-10 - Terminal 30 missing - Intermittent
Address 45: Inter. Monitor
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 02325
Address 76: Park Assist
Controller: 8Z0 919 283
Component: Parkingsyst. A6 RDW D08
Coding: 00106
Shop #: WSC 02325
3 Faults Found:
01545 - Sensor for Parking Aid: Rear Left (G203)
37-10 - Faulty - Intermittent
01547 - Sensor for Parking Aid: Rear Mid-Right (G205)
30-10 - Open or Short to B+ - Intermittent
01548 - Sensor for Parking Aid: Rear Right (G206)
30-00 - Open or Short to B+
End --------------------------------------------------------------------------------------------------
Do you need any additional information?
Old Nov 15, 2009 | 12:49 PM
xewax's Avatar
The engine vibrates when it is worm because rpm is too low.
Old Nov 16, 2009 | 02:11 PM
Dana @ Ross-Tech's Avatar
You mentioned it was sitting for a while. Have you replaced the air and fuel filters recently? One other note, has the intake manifold been checked for excessive carbon / restriction?
To answer the idle question...look in Adaptation, Channel 2: Idle Speed. See if this applies to your Ecm. I would only do that if the other maintenance type items mentioned above appear to be fine or were already replaced.
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 16, 2009 | 10:01 PM
xewax's Avatar
What does Ecm stand for?
Old Nov 17, 2009 | 04:25 AM
Banned
ECM = Engine Control Module.
-Uwe-
