Problems with A4
1. in (46) I changed cluster to follow any non-USA format and as a result I will be unable to unlock all the doors using internal unlock switch (only trunk will unlock) code: 03301
I wanted to use GB pattern because it gives me 24h clock
2. needles and ranges on cluster. (17,ch19) I am unable to get both ranges and needles to work on lights OFF, I can use mode 1 and 2, but 3 won't work.
3. Seatbelts, I get no seatbelt chime/whine/icon/ w/e in the cluster when I don't have seatbelts on, I looked around and everything seemed fine. There is so much code and I don't know what to post here. I checked in airbag section and it detects that seatbelts engage.
Please tell me what code you need to see (and where to find it) so I will post it later next day.
As always thanks for Your continued help.
VAG-COM Version: Release 704.1
Data version: 20070422
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAULT68E72A227896 Mileage: 95870km/59570miles
Address 01: Engine Labels: None
Part No SW: 8E0 909 559 D HW: 8E0 909 059
Component: 3.0L V6/5V G 0003
Coding: 0016711
Shop #: WSC 63351
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-614-517.LBL
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04495
Shop #: WSC 06435
Address 08: Auto HVAC Labels: 8E0-820-043.LBL
Part No: 8E0 820 043 G
Component: A4 Klimaautomat 0912
Coding: 00000
Shop #: WSC 63351
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
Part No: 8E0 907 279 E
Component: int. Lastmodul USA 0305
Coding: 00003
Shop #: WSC 63351
Address 15: Airbags Labels: 8E0-959-655-84.LBL
Part No: 8E0 959 655 A
Component: Airbag 8.4E 5000
Coding: 0010607
Shop #: WSC 63351
Address 16: Steering wheel Labels: 8E0-953-549.LBL
Part No: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 00041
Shop #: WSC 63351
Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
Part No: 8E0 920 950 H
Component: KOMBI+WEGFAHRS. RB4 D26
Coding: 03401
Shop #: WSC 06108
WAULT68E72A227896 AUZ6Z0A0364883
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.LBL
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0203
Coding: 00002
Shop #: WSC 63351
Address 45: Inter. Monitor Labels: 8E0-951-177.LBL
Part No: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
Part No: 8E0 959 433 T
Component: Komfortgerát T5B 0617
Coding: 11880
Shop #: WSC 63351
Part No: 8E1959801
Component: Tõrsteuer.FS BRM 0002
Part No: 8E1959802E
Component: Tõrsteuer.BF BRM 0002
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0002
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0002
10 Faults Found:
01581 - Incorrect Component Detected
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01574 - Alarm triggered by Door Contact Switch; Right Rear
35-00 - -
01559 - Drivers Door
61-10 - Won't De-Safe - Intermittent
01560 - Passenger Door
01561 - Left Rear Door
01562 - Right Rear Door
Address 56: Radio Labels: 8E0-035-1xx-56.LBL
Part No: 8E0 035 195 A
Component: symphony II NP2 0008
Coding: 00001
Shop #: WSC 00000
End --------------------------------------------------------------------------------------------------
35-00 - -
I think your central convenience module is dodgy. It's clearly coded for "No SAFE-function USA only" yet it bitches that it can't De-Safe. I moght try clearing the fault codes from that module, and possibly cold-booting it.
-Uwe-
Chassis Type: 01 - 2002 A4 V6
Scan: 01 03 08 09 15 16 17 25 36 45 46 56 56
Coding: 0016711
Shop #: WSC 63351
Readiness: 0110 1101
Coding: 04495
Shop #: WSC 06435
Coding: 00000
Shop #: WSC 63351
Coding: 00003
Shop #: WSC 63351
Coding: 0010607
Shop #: WSC 63351
Coding: 00041
Shop #: WSC 63351
Coding: 03203
Shop #: WSC 06108
Address 25: Immobilizer Labels: None
Part No: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Coding: 00002
Shop #: WSC 63351
Coding: 11880
Shop #: WSC 63351
Part No: 8E1959801
Part No: 8E1959802E
Part No: 8E0959801A
Part No: 8E0959802A
Coding: 00001
Shop #: WSC 00000
Coding: 00001
Shop #: WSC 00000
There's several way to accomplish that. Disconnecting the battery for a while, pulling the relevant fuses, or disconnecting the module from the car. I'd probably disconnect the battery.
-Uwe-
