Question re: testing ABS controller
The airbag controller has <u>never</u> thrown a code -- even when the light is on or flickering in front of my eyes, as I'm scanning it. I've tried disconnecting/reconnecting various connectors to no avail. And it's done this with 2 separate instrument clusters, so I doubt it's a bad cluster.
Question: <b>Because the airbag controller shows no DTCs, is it wise to assume the problem is elsewhere?</b> I know that seatbelt connectors and other things can trigger the light. <b>Any tips on sleuthing this out with my Vag-com?</b> I've also posted this on Bentley's forums and found several others with the problem, but nobody has a solution. I'm stumped. \_Q_/
TIA, ~john
Group <b>001</b> ~"Correct" resistance in values 1 through 4
(that is, both front airbags and both seat belt pretensioners)
Group <b>006</b> ~"Correct" resistance in values 1 and 2
(that is, driver's and pass' side airbag igniters)
And yet the light still comes on at a cold start, eventually flickering erratically before finally turning out after about 10 mins. The Bentley CD offers little help in sleuthing this out. <b>Any suggestions would be greatly appreciated.</b>
