VAG-COM Discussion
S8 - Two persistent error codes - Any ideas?
Old May 14, 2007 | 12:23 PM
lefteris_gr's Avatar
New Member
Default S8 - Two persistent error codes - Any ideas?
I keep getting error codes on the same 2 components - on a two week old car.
Error 1) Address 1E: Media Player 2
02261 - Media Player; Position 1 (R118)
014 - Defective
Error 2) Address 61: Battery Regul.
2 Faults Found:
02272 - Rest Current Stage 1
000 - - - Intermittent
02273 - Rest Current Stage 2
or:
1 Fault Found:
02275 - Rest Current Stage 4
I cleared the fault codes a couple of times and re-scanned but I persistently get the same error on the media player and the same or another error on the battery regulator.
I took the car to the dealer for an oil change (I didn't mention anything about the fault codes) but the dealer simply deleted them from the memory.
Does anyone know what these codes mean?
Thanks,
L.
Old May 15, 2007 | 04:37 AM
Uwe@Ross-Tech.com's Avatar
Banned
Default The faults in the Battery Regulation
mean that it thinks your battery is getting a tad low and it's asking other systems to shed load. This is pretty much normal on those cars if you leave the ignition on for any length of time without the engine running.
As far as Media Player 2, I'm not even sure exactly what that system is in your car. Post the ID data from it. Does all the entertainment stuff in the car work as it should?
-Uwe-
Old May 15, 2007 | 08:08 AM
New Member
Default Re: Media Player 2 Data
Yes, Radio, CD, TV, ipod (as well as the rather entertaining back massage feature) work fine as far as I can tell.
Address 1E: Media Player 2 Labels: None
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H44 0350
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 7
Fault Frequency: 1
Reset counter: 36
Mileage: 3103 km
Time Indication: 0
Date: 2007.05.08
Time: 18:53:29
Freeze Frame:
Text: 00000000
Thanks,
L.
Old May 15, 2007 | 10:21 AM
Banned
Default If everything works as it should, I wouldn't worry about it.
The A8/A6/Q7 type cars are know for throwing an occasional fault code in the various MMI components ..;-)
-Uwe-
Old May 15, 2007 | 10:54 AM
New Member
Curious, more than worried ;-) Thanks.
Old May 16, 2007 | 05:54 AM
New Member
Default Brought it to the dealer and inquired about the Media Player fault
kinda funny actually...
the mechanic plugs the car into the "official" diagnostics thingy, sees the error codes....
and says: "Hmm. I've no idea what this is. Probably something to do with the audio system. Never mind. I'll just erase it for you..."
As I'm standing over his shoulder, STUNNED!
"Dude, shouldn't you know something more? You're an authorized Audi shop"
"Well, these are really complicated cars. Have a good day, Sir."
"...Yeah. Thanks. For nothing."
Old May 16, 2007 | 07:19 AM
Banned
Default It's true, they are really complicated,
the MMI system has over 100 MB of software (not counting the Navigation Data!) and it's simply not unusual for for it throw some spurious fault codes.
As I said, if everything works as it should, I wouldn't worry about it.
-Uwe-
MT Born
Nov 27, 2016 11:39 AM
allenst
Feb 19, 2015 07:11 AM
singhl
Feb 12, 2009 12:51 AM
GreenA4
Dec 4, 2008 11:51 AM
nova309
Mar 6, 2003 07:28 AM
