serious issues w sirius reception
today in a open parking lot i drove car in a big circle and reception is lost when vehicle points South West.
thanks in advance
here is my scan
*ran w tuner off
*engine off but veh in accessory mode
*TMPS not installed on wheels or active in MMI
Monday,24,October,2011,09:51:31:31219
VCDS Version: Release 10.6.4
Data version: 20110418
Chassis Type: 4F0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
53 55 56 61 62 67 72 76 77
VIN: WAUEL74F45N091351 Mileage: 161120km/100115miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: None
Part No SW: 4F0 910 560 A HW: 4F0 907 559
Component: 4.2L V8/5V G 0020
Revision: --H01--- Serial number:
Coding: 0007772
Shop #: WSC 02325 785 00200
VCID: 2045085B8A53
1 Fault Found:
17981 - Left Engine Mount Solenoid Valve (N144): Open Circuit
P1573 - 004 - No Signal/Communication
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 G HW: 09L 927 156
Component: AG6 09L 4.2L5V USA 0080
Revision: 00000001 Serial number: ÿÿÿÿÿÿÿ
Coding: 0000002
Shop #: WSC 40235 444 83925
VCID: 2855107BE263
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H03 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0021352
VCID: 2D5BE16FCD81
Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0180
Revision: 30070501 Serial number: 10600300117315
Coding: 0000015
Shop #: WSC 40235 444 59543
VCID: E3CFC7575BC5
Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H43 0070
Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H25 0070
1 Fault Found:
01049 - Supply Voltage Term 50
006 - Short to Plus
Freeze Frame:
Fault Status: 01110110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 151
Mileage: 121338 km
Time Indication: 0
Date: 2010.05.12
Time: 13:16:37
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 732 Q HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 360AL057514863
Coding: 0000003
VCID: 3163FD1FD1B9
Part No: 4F0 910 609
Component: Bedienteil MMIC6H07 0870
1 Fault Found:
00658 - Control Head
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 183
Mileage: 160400 km
Time Indication: 0
Date: 2011.10.12
Time: 15:33:40
Freeze Frame:
Bin. Bits: 001
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 J
Component: KLIMABETAETIGUNGH11 0110
Revision: 00000024 Serial number: 00000000102166
Coding: 0008232
VCID: DBBFFFB763B5
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 A HW: 4F0 907 279 A
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0113123
Shop #: WSC 02335 785 00200
VCID: 27571347EF7D
Part No: 4F1 910 113
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 02335
Part No: 4E0 910 557
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBD7105934
Shop #: WSC 00000 000 00000
VCID: 1C3D3CABA63B
1 Fault Found:
02244 - Button in Control Head is Stuck
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 7
Fault Frequency: 1
Reset counter: 187
Mileage: 160502 km
Time Indication: 0
Date: 2011.10.14
Time: 09:15:19
Freeze Frame:
Bin. Bits: 01000000
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 D HW: 4E0 035 593
Component: SDAR SIRIUS H04 0670
Revision: 00000000 Serial number: AUZ4Z7F0012096
VCID: 2855107BE263
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 188
Mileage: 154499 km
Time Indication: 0
Date: 2011.08.06
Time: 02:35:32
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 B HW: 4F0 959 655 A
Component: 56 AIRBAG AUDI8RH29 0310
Revision: 10H29000 Serial number: 00359D085YNE
Coding: 0013622
Shop #: WSC 02135 444 83925
VCID: 26491E43E877
Part No: 4F0 910 339
Component: BF-Gewichtsens. 002 0040
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 B
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90025050070529
Coding: 0012241
Shop #: WSC 02323 785 00200
VCID: E6C9DE43A8F7
Part No: XXXXXXXXXXX
Component: Lenkradmodul H06 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 950 M
Component: KOMBIINSTR. M73 H10 0570
Revision: 00200000 Serial number: 4R812DHD4
Coding: 0065263
Shop #: WSC 08283 444 84066
VCID: 1E3936A3B027
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 08008051030171
Coding: ECFE73CC1B7904
VCID: 27571347EF7D
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082954
VCID: E1C3CD5F41D9
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
Component: MNS US H43 1100
Revision: 00000000 Serial number: 378AK057510380
VCID: 3875C03B32C3
2 Faults Found:
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 7
Fault Frequency: 171
Reset counter: 206
Mileage: 145688 km
Time Indication: 0
Date: 2011.04.24
Time: 23:47:38
Freeze Frame:
Hex Value: 0x4EA3
Hex Value: 0xEE63
Hex Value: 0x0F00
Hex Value: 0x3B68
02927 - DVD Read Error
Freeze Frame:
Fault Priority: 6
Fault Frequency: 13
Reset counter: 208
Mileage: 157650 km
Time Indication: 0
Date: 2011.09.06
Time: 09:41:53
Freeze Frame:
Hex Value: 0x4EA5
Hex Value: 0x3308
Hex Value: 0x04FF
Hex Value: 0x0000
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H10 0020
Revision: 00000000 Serial number: ƒ9
Coding: 0051947
Shop #: WSC 02327 785 00200
VCID: 2953157FF969
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H15 0100
Revision: 01000015 Serial number: 01002385320000
Coding: 0425021
VCID: 2C5DEC6BF69B
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Address 47: Sound System Labels: None
Part No SW: 4F5 910 223 F HW: 4F5 035 223 E
Component: DSP-High C6 H14 0330
Revision: PROD_01 Serial number: 00000000021498
Coding: 0000026
VCID: 26491E43E877
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H09 0050
Revision: Serial number: 00000000057354
Coding: 0011114
VCID: DEB9F6A370A7
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H10 0020
Revision: 00000000 Serial number: 7@
Coding: 0051947
VCID: 2953157FF969
Address 53: Parking Brake Labels: 4F0-910-801.lbl
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0006022
Shop #: WSC 02334 785 00200
VCID: DDBBF1AF7DA1
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0020
Coding: 0000016
VCID: 26491E43E877
Part No: 4F0 941 329 A
Component: AFS-Modul links H05 0010
Component: AFS-Modul rechtsH05 0010
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394LV047510266
Coding: 0000002
VCID: 3163FD1FD1B9
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0470
Revision: 00000000 Serial number: 00000000002940
Shop #: WSC 02135 444 58902
VCID: 234F07579B45
Part No: 4F0 915 105 D
Component: von VA0 9999999999
Coding: 344630393135313035442056413039393939393939393939
Shop #: WSC 02137 444 83925
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 795
Component: TSG HL H09 0010
Coding: 0051754
VCID: E9D3D57FB9E9
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000501130178
Shop #: WSC 12336 024 394758
VCID: 346DF40B2EAB
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 HW: 4F0 959 794
Component: TSG HR H09 0010
Coding: 0051754
VCID: E9D3D57FB9E9
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 HW: 4F0 919 283
Component: Parkhilfe 4-Kan H09 0030
Revision: --.--.-- Serial number: 11720501201255
Coding: 0001206
Shop #: WSC 131071 1023 2097151
VCID: E1C3CD5F41D9
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H10 1130
Revision: 00000000 Serial number: 00000007512655
Coding: 0010900
VCID: 2855107BE263
End ---------------------------------------------------------------------
Has the sat radio been OK up to now? I'm in the NE USA and my reception might be characterized as spotty when driving under trees, which is frequent along my routes. I know my VCDS scan almost always shows a fault on the radio. I think it says intermittent communication error. I clear it and it comes back soon.
When I renewed my subscription a few months ago, I complained about the spotty reception and the person on the phone did something to re-initialize (perhaps not the correct term) my radio, it took a good 5 mins or longer. I don't believe it improved the radio's performance at all.
i knew about the solenoid, Nav and SAT Rad errors... the others are new. i am currently trying to work out the SatRad issue and will work on the others so ANY and ALL advice on any faults is GREATLY appreciated. Back to SAT.. Sat worked great last year i remember driving thru streets almost completely covered from old tree growth from both sides of the street and the whole length of the street forming one huge tunnel and my reception was GREAT. even going from burbs thru downtown again no loss. now seems like past few moths my reception has degraded progressively. it had gotten so bad i let Sirius expire, this week i responded to a promotion and reactivated my account. the day i called it was cloudy w rain and i could not receive the activation signal at all. the next day the 1st part of day no rain but overcast the 2nd half was hazy and still could not receive signal. finally on a clear night sky i called the automated line to resend the activation signal and it finally was received. well u can guess i loose reception under just about every overpass, large trees or tall bldgs. i believe that Sirius has a delay or oversampling (sim to anti skip) to help with signal drops but maybe this can only go so far... i live minutes from the shore and work at the shore... i should have above avg line of sight (see pics)
i am hoping i have a frayed or loose wire n i should open her up to look
but its looking like my antenna is broken n i should buy a replacement
what does all this indicate?
this is how sky looks and i lose reception *traveling south no trees no tall bldgs just occasional billboards
there is a TSB on the nav unit...im thinking mine was never replaced when veh was under warranty.
i get "check DVD" error MMI display will freeze up while in Nav mode and give error then sometimes return back functioning normally but will freeze up again moments laters (oddly the DIS display in elec dash cluster still functions giving me step by step arrowed directions and audible turns
some say either a bad burn on disk or bad nav unit
People in the center of the USA are at a distinct advantage with the Sirius thing - - the satellite must be held over the center of the country. I'm kind of on the coastal fringes and suffer frequent drop outs. FWIW, I've read a lot of comments about this issue on different car forums. I've seen many comments that suggets the Euro cars suffer the worst.
Open VCDS in your car with the sat radio on. Select control module OF which should be found in the "Electronics 2" tab at the top.
Select Measuring Blocks 08. Use the up/down button to put a block in a group. The ones of interest are blocks 5 and 8. The definitions are in the label file at the upper left. Your block 8 may differ from the VCDS label definition by indicating a different value in the second and third position. My understanding is that if it displays 194, the respective antenna is OK.
This is amateur info based on my experience with my OF module. Go to the Ross-Tech home page and select "Manual" at the top. It is interactve and is very helpful to learn how to navigate into measuring blocks, just ignore the data supplied as examples.
I hope I haven't told you more than you wanted to know. By the way, I haven't solved my problem. I would like find a known good OF module to try and determine if it is the module or not because the antennas and the fiber optics are OK..
