VAG-COM Discussion
Tiptronic recode
Old Jun 8, 2003 | 06:43 AM
agw2's Avatar
Default Tiptronic recode
My TCU model is 8D0 927 156 BN
It currently shows code 00000.
When I try recoding it the new code won't take.
I'm using VAG-HEX and I succesfully recoded the instrument cluster. Any clues?
I tried 00032; 00022; 00030; 00020; 00011; 00012
Also there are different information available with regards to what each code does, does anyone have a list and the applicable TCU number?
What I'd like to do ideally is to render the shifting a little sportier.
Old Jun 8, 2003 | 07:18 AM
rickw's Avatar
Default Re: Tiptronic recode
It won't take a recode with the engine running. That's not the problem, is it?
My TCM is a BS suffix if that matters.
IIRC:
00002 is stock
00012 is sport mode
00022 deletes auto 1-2 shift in Tip mode
00032 combines 00012 and 00022
Old Jun 8, 2003 | 03:47 PM
agw2's Avatar
Hi Rick,
Thanks for the info; very clear and meaningful.
No, the engine is not running, just the key turned to turn the instrument cluster on.
As I said my code shows 00000 not 00002. Could it be because I took the ECU out (at some point I had a GIAC tip chipped ECU) and now put it back?
Should I run the adaptation like it is done with the Engine ECU?
Lastly, when you say "00022 deletes auto 1-2 shift in Tip mode" you mean that 1st gear is held until limiter or manual change correct?
I'm asking because my experience is that 1st gear is indeed held with the current coding (I'm going to take a trip and re-check) but I remember that I once tried an S4 Tip and on that car the 1st was shifting to 2nd right away even in Tip mode.
Old Jun 8, 2003 | 10:34 PM
rickw's Avatar
Default I've only done the recode on the S4 Tip,
I understand it works on the A6 also. I don't know about the A4 or any others. My TCM has the GIAC Tip chip and takes the codes successfully. The "automatic 1-2 shift in Tip mode" delete allows you to hold 1st gear until redline, or until you let up on the accelerator, at which time it auto shifts to 2nd. I don't believe the Tip automatic 1-2 shift behavior is programmed into the A4, if that's what you've got. Sorry I can't be of more help.
Old Jun 8, 2003 | 10:49 PM
E Vader's Avatar
Member
Default I notice that the recode requests........
.......another input code in the lower box below the tip recode area. Is it necessary to have this code to recode the TCU? Or is my TCU not accepting the recode due to the fact that I alreay have the GIAC upgrade?
As of yet I have had no success getting my car to accept the recode..........feedback........
Old Jun 8, 2003 | 11:18 PM
rickw's Avatar
Default Re: I notice that the recode requests........
Don't know about A4 recodes, sorry.
Old Jun 14, 2003 | 06:32 AM
dbs42002's Avatar
New Member
Default Make sure engine is off with key in on positon.....
try this, i trried it with engine on and could not do it, When i shut it off i could even with tip chip.
Michael Benno
Audi allroad
10
Jun 26, 2007 11:51 AM
angryswede
VAG-COM Discussion
May 5, 2004 07:59 PM
Damisguy
Jan 17, 2003 10:58 PM
TOASTY
9
Jan 10, 2002 03:06 PM
Jim De Arras
Performance and Tuning
Apr 1, 2001 06:10 AM
