Tons of codes...?
-Sean
2 Faults Found:
00526 - Brake Light Switch-F
36-10 - Open Circuit - Intermittent
27-10 - Implausible Signal - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
Part No: 8E0 907 279 F
Component: int. Lastmodul USA 0517
Coding: 01013
Shop #: WSC 06435
1 Fault Found:
02104 - Light Detection Sensor (G399)
29-10 - Short to Ground - Intermittent
Address 0F: Digital Radio Labels: 8E0-035-593-XM.LBL
Part No SW: 8E0 035 593 A HW:
Component: SDAR XM 60010
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
Part No: 8E0 920 981 G
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 01231
Shop #: WSC 01110
WAUPL68E14A152892 AUZ6Z0C0368430
1 Fault Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.LBL
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 06435
1 Fault Found:
00668 - Supply Voltage Terminal 30
06-10 - Signal too High - Intermittent
Address 37: Navigation Labels: 8E0-035-192-RNSE.LBL
Part No SW: 8E0 035 192 C HW: 8E0 035 192 C
Component: RNS-E US3 H58 X---
Coding: 0301611
Shop #: WSC 00000
8 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 5
Reset counter: 69
Time Indication: 0
Date: 2007.04.07
Time: 10:46:44
Freeze Frame:
Voltage: 12.10 V
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 24
Reset counter: 69
Time Indication: 0
Date: 2007.02.01
Time: 09:30:04
Freeze Frame:
Voltage: 10.50 V
Mileage: 655350 km
Count: 401
Clock: 17:44
02244 - Button in Control Head is Stuck
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 2
Reset counter: 43
Time Indication: 0
Date: 2007.11.24
Time: 18:43:39
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 001
00856 - Radio Antenna
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 43
Time Indication: 0
Date: 2003.08.01
Time: 00:00:28
Freeze Frame:
Mileage: 655350 km
Count: 2411
Clock: 18:06
00852 - Loudspeaker(s); Front
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
01305 - Databus for Infotainment
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 182
Reset counter: 43
Time Indication: 0
Date: 2003.08.01
Time: 00:38:05
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 224
Time Indication: 0
Date: 2007.10.27
Time: 12:35:30
02446 - Disk Drive Mechanical Malfunction
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 41
Time Indication: 0
Date: 2006.12.18
Time: 15:48:28
Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1411
Coding: 11788
Shop #: WSC 06435
Part No: 8E1959801
Component: Tõrsteuer.FS BRM 0004
Part No: 8E1959802E
Component: Tõrsteuer.BF BRM 0004
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0004
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0004
No fault code found.
Address 55: Xenon Range Labels: 4Z7-907-357.LBL
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 06435
Address 56: Radio Labels: 8E0-035-192-RNSE.LBL
Coding: 0301611
Shop #: WSC 00000
8 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 69
Time Indication: 0
Date: 2007.04.07
Time: 10:46:44
Freeze Frame:
Voltage: 12.10 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 24
Reset counter: 69
Time Indication: 0
Date: 2007.02.01
Time: 09:30:04
Freeze Frame:
Voltage: 10.50 V
Mileage: 655350 km
Count: 401
Clock: 17:44
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 43
Time Indication: 0
Date: 2007.11.24
Time: 18:43:39
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 001
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 43
Time Indication: 0
Date: 2003.08.01
Time: 00:00:28
Freeze Frame:
Mileage: 655350 km
Count: 2411
Clock: 18:06
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 0
Freeze Frame:
Fault Priority: 5
Reset counter: 43
Time Indication: 0
Date: 2003.08.01
Time: 00:38:05
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 224
Time Indication: 0
Date: 2007.10.27
Time: 12:35:30
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 41
Time Indication: 0
Date: 2006.12.18
Time: 15:48:28
Address 77: Telephone Labels: 8P0-862-335.LBL
Part No SW: 8P0 862 335 J HW: 8P0 862 335 J
Component: FSE_255x BT H25 0290
Coding: 0011777
Shop #: WSC 00000
End --------------------------------------------------------------------------------------------------
