VAG-COM Discussion
TPMS battery life measuring block
Old Aug 6, 2011 | 11:14 AM
jakematic's Avatar
Default TPMS battery life measuring block
Part way through my drive to camp for vacation a TPMS warning came on in DIS and went away seconds later with no MIL.
A couple of days ago TPMS was off when I started the car and would not turn back on.
Next time around everything came back to "normal".
VCDS shows the life as 71 months on 3 sensors and 72 on the fourth.
Yes, yes I do travel with VCDS on any trip longer than a couple hours
Is this time left, or time that has already passed?
Old Aug 12, 2011 | 04:25 PM
Theresias's Avatar
Time left, so you should be good on that end. Any other codes stored? Mind posting an Auto-Scan?
Old Aug 13, 2011 | 07:43 AM
jakematic's Avatar
Thanks Sebastian - puts my mind at ease.
Prompted me to revisit the original owner's service records and I see TPMS sensors were replaced about a year ago.
The car had been sitting overnight so I find the temperature reported by module 65 highly unlikely !
The sunroof got stuck closing, promptly reversed and threw the pinch protection code - might need to be greased/cleaned.
The parking brake error is "normal", but do not recall seeing the 008 fault before.
Auto-Scan follows.
Thanks-Jake
Tuesday,02,August,2011,12:14:35:50323
VCDS Version: Release 10.6.4
Data version: 20110418
JakeWare Solutions
Chassis Type: 4E0
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 67 72 77
VIN: WAUML44E45N014125 Mileage: 130150km/80871miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 J HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0E0757767
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 2855F28CE263
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 S HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0030
Revision: --H01--- Serial number: 0051811
Coding: 0000002
Shop #: WSC 09222 444 53302
VCID: 326110E4D4BF
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0007597
Shop #: WSC 05003 000 00000
VCID: 2241E0A4845F
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 D
Component: FBS AUDID3 H04 0140
Revision: 01404004 Serial number: AUX3Z0E0757767
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: D8B5024C1283
Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H08 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940448
Shop #: WSC 00000 785 00200
VCID: 234FE5A09B45
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 731 H HW: 4E0 035 729
Component: Interfacebox H43 2740
Revision: 00000000 Serial number: 346AR057519329
Coding: 0000003
Shop #: WSC 05146 444 64369
VCID: 2649FCB4E877
Part No: 4E0 910 609 C
Component: Bedienteil MMI H42 0100
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 A HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 016 0340
Revision: 00000029 Serial number: 00000000060137
Coding: 1052993
VCID: 1B3FDD40A335
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 L HW: 4E0 907 279 L
Component: ILM Fahrer H12 0210
Coding: 0123123
VCID: 31631FE8D1B9
Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000034
Shop #: WSC 02313
Part No: 4E0 910 557
Component: REGENLICHTSENSORH10 0050
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBD7106255
Shop #: WSC 00000 000 00000
VCID: 1C3DDE5CA63B
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 D HW: 4E0 035 593
Component: SDAR SIRIUS H04 0670
Revision: 00000000 Serial number: AUZ4Z7D3007378
VCID: 2855F28CE263
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
VCID: 244DE6BC9E4B
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenks�ulenmodul H13 0040
Coding: 0012241
VCID: E5CB3BB855F1
Component: Lenkradmodul H05 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 G HW: 4E0 920 950 G
Component: KOMBIINSTR. VDO H53 0210
Revision: D05 Serial number: AUDID3E0004043
Coding: 0016203
Shop #: WSC 09222 444 14580
VCID: 2855F28CE263
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0040
Revision: 07 Serial number: 05005051032834
Coding: 7CFE7BDD1B7904
VCID: 2649FCB4E877
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
VCID: D8B5024C1283
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
Shop #: WSC 09222 444 58773
VCID: 2855F28CE263
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H08 0060
Coding: 4071530
VCID: 234FE5A09B45
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
Component: MNS US H44 1100
Revision: 00000000 Serial number: 378BW057517816
Shop #: WSC 05146 444 59366
VCID: 387522CC32C3
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H02 0090
Serial number: 00000501700156
Coding: 0003477
VCID: 1D3BD358BD21
2 Faults Found:
00457 - Control Module for Network (J519)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 4
Mileage: 129704 km
Time Indication: 0
Date: 2011.08.01
Time: 17:53:00
02282 - Sunroof Drive; Obstruction Detection
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 5
Mileage: 130152 km
Time Indication: 0
Date: 2011.08.02
Time: 11:39:00
Address 42: Door Elect, Driver Labels: None
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: T�rsteuer.FS BRM003 0100
Coding: 0028204
Shop #: WSC 05146 444 83888
VCID: 2045EAAC8A53
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040501100006
Coding: 0065150
VCID: 2757F1B0EF7D
Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Part No: 4E0 907 719
Component: Neigungssensor H03 0020
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 K HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0440
Revision: PROD_01 Serial number: 00000000010457
Coding: 0000016
VCID: 254BFBB89571
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000054181
Coding: 0010111
VCID: 1E39D454B027
Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Address 52: Door Elect, Pass. Labels: None
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: T�rsteuer.BF BRM002 0060
Coding: 0028204
VCID: 2045EAAC8A53
Address 53: Parking Brake Labels: 4E0-910-801.lbl
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000532
Shop #: WSC 08213 444 69273
VCID: 1D3BD358BD21
1 Fault Found:
02596 - Rear Brake Pads Worn
008 - Implausible Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 94
Time Indication: 0
Freeze Frame:
Voltage: 10.35 V
Count: 61
Address 55: Xenon Range Labels: None
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Revision: 00000001 Serial number:
Coding: 0000001
VCID: E2C120A444DF
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 M HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0570
Revision: 00000000 Serial number: 396AM057503425
Coding: 0000002
VCID: 2A510884FC6F
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0510
Revision: 00000000 Serial number: 00000000000204
VCID: 2045EAAC8A53
Part No: 4E0 915 105 A
Component: von VA0 2603280968
Coding: 344530393135313035412056413032363033323830393638
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: T�rsteuer.HL BRM002 0060
Coding: 0028204
VCID: 1E39D454B027
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010028 Serial number: 00000900030219
Coding: 0232125
VCID: DFC7295077AD
1 Fault Found:
01470 - Rear Right Tire Pressure Sensor (G225)
004 - No Signal/Communication - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 5
Mileage: 129065 km
Time Indication: 0
Date: 2011.08.01
Time: 11:22:01
Freeze Frame:
Speed: 97.0 km/h
Voltage: 14.10 V
(no units): 55.0
Temperature: 49.0�C
Temperature: 47.0�C
Temperature: 46.0�C
Temperature: 127.0�C
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000501210190
Shop #: WSC 12336 024 394758
VCID: 346D16FC2EAB
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: T�rsteuer.HR BRM002 0060
Coding: 0028204
VCID: 1E39D454B027
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 D HW: 4E0 862 335
Component: Handyvorb2 H10 0700
Revision: 00000000 Serial number: 00000007512824
Coding: 0010900
VCID: 244DE6BC9E4B
End ---------------------------------------------------------------------
jakematic
12
Aug 18, 2011 05:13 PM
Egil A64.2s - S6
9
Sep 9, 2008 06:44 PM
tx170754
Oct 10, 2007 10:06 AM
Raddue
Pacific Northwest Discussion
24
May 24, 2007 09:18 PM
MiS4terTed
Oct 20, 2005 01:25 PM
