VAG-COM Discussion
unable to do basic setting for automatic trany
Old Nov 26, 2004 | 09:44 PM
wisam's Avatar
New Member
Default unable to do basic setting for automatic trany
i am usin vag-com version 311-2,the
interface is a serial port with 2x2 adapter and the group is 000.
i am trying to use the basic setting for the
automatic transmission controler(096 ape # 095 927 731BE in 1990 vw passat). when i try the output test, i get an erorr message. i can read the meas. block with no problem but when i switch to the basic setting screen i get nothing,no message and the little bar stops spinning and the fields stay blank. don't i need to go to login first? if i do, does anyone have the 5 digit login code for that controler.
keeping in mind i had no problem with the # 01 engine controler.
i can use all the help i can get, thank you very much.
sam
4point2slc
Salt Lake City Discussion
Mar 25, 2007 08:56 PM
gb944
VAG-COM Discussion
Dec 1, 2005 08:14 AM
AudiJon
Sep 21, 2004 07:49 PM
s54m3
Oct 25, 2002 02:11 AM
FrankS
May 17, 2001 07:37 AM
