Updated/additional lable files and general help?
It's a UK B5 2.4SE, the first scan I did is all I have to hand...but think that gives the details of the modules I have, so are there label files for all of these - any other info you need?
Also, should I be able to get into address 25, the imobiliser?? And confused about the readiness status under engine - should I get a passed in all areas - I thought if you did not have monitoring on one area, it got passed automatically, but I have 2 that never seem to pass - but can't remember which two !!
VAG-COM Version: Release 607.3-UD
Wednesday,29,November,2006,11:24:48
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
VIN Number: WAUZZZ8DZ1A021256
Address 01: Engine
Part No: 3B0 907 552
Component: 2.4L V6/5V G 0002
Coding: 11551
Shop #: WSC 06435
WAUZZZ8DZ1A021256 AUZ7Z0Y1484545
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans
Part No: 8D0 927 156 DG
Component: AG5 01V 2.4l5V RdW 1111
Coding: 00003
Shop #: WSC 06435
Address 03: ABS Brakes
Part No: 3B0 614 111
Component: ABS/ASR 5.3 FRONT D00
Coding: 00031
Shop #: WSC 06435
Address 08: Auto HVAC
Part No: 8D0 820 043 Q
Component: A4 KLIMAAUTOMAT D58
Coding: 00061
Shop #: WSC 06435
Address 15: Airbags
Part No: 8D0 959 655 J
Component: Airbag Front+Seite 1001
Coding: 01104
Shop #: WSC 06435
Address 17: Instruments
Part No: 8D0 920 980 K
Component: B5-KOMBIINSTR. VDO D12
Coding: 02462
Shop #: WSC 00340
Address 25: Immobilizer
Part No: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 35: Centr. Locks
Part No: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D13
Coding: 16234
Shop #: WSC 00350
2 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01134 - Alarm Horn (H12)
77-00 - Internal Supply Voltage
Address 45: Inter. Monitor
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06435
Address 56: Radio
Part No: 8D0 035 195
Component: Radio D00
Coding: 00012
Shop #: WSC 06435
1 Fault Found:
00850 - Control Output Active; Radio Amplifier
29-10 - Short to Ground - Intermittent
End --------------------------------------------------------------------------------------------------
Then run another Auto-Scan. Now VAG-COM will show you the name of the label file it can find for each module in your car.
No, you should not be able to get Address 25. "Bitte Adresse 17 eingeben" is German for "Please use address 17". That's because your Immoboilizer is integrated in your instrument cluster.
In the scan you posted, all your Readiness bits read "Pass".
-Uwe-
I'll have a look with the debug option...
- means not covered by a label file
- Address 01: Engine (3B0 907 552)
+ Address 02: Auto Trans (8D0 927 156 DG)
- Address 03: ABS Brakes (3B0 614 111)
- Address 08: Auto HVAC (8D0 820 043 Q)
+ Address 15: Airbags (8D0 959 655 J)
- Address 17: Instruments (8D0 920 980 K)
+ Address 35: Centr. Locks (8D0 862 257 E)
+ Address 45: Inter. Monitor (4B0 951 173)
- Address 56: Radio (8D0 035 195)
So after all not a satisfying result for us.
Please contact me directly via email, we should be able to fill the gaps with a bit of your help.The #25 says "Bitte Adresse 17 eingeben", that's German for "Please Enter Address 17" and tells you that the immobilizer is part of the instrument cluster.
