VAG-COM Discussion
vag-com compatible with
Old Nov 13, 2005 | 08:58 AM
arthuraudi's Avatar
Default vag-com compatible with
the 1990 coupe quattro? I see the connectors and the software find the controller but it does not read any fault codes...
even do the engine light comes on while driving over 70mph and the engine is warmed up, thanks.
Old Nov 14, 2005 | 04:10 AM
Uwe@Ross-Tech.com's Avatar
Banned
Default If VAG-COM finds the ECU, then it's compatible
But understand that the fault detection logic on a 1990 ECU is rudimentary at best and VAG-COM can only show you faults which the ECU has detected (and stored).
-Uwe-
Old Dec 12, 2005 | 06:48 PM
arthuraudi's Avatar
Default Re: If VAG-COM finds the ECU, then it's compatible
vag number: 893 906 266 B
MOTOR PMC 110
gateway
Sep 4, 2010 06:11 PM
internecine
VAG-COM Discussion
Apr 28, 2005 08:57 AM
STEVE2.7T
Feb 19, 2003 04:00 AM
jlh28@work
Oct 7, 2002 05:23 PM
DarinS4Turbo
Apr 24, 2001 05:40 AM
