Vag com login.....how
Monday,17,December,2007,22:59:51:55371
VAG-COM Version: Release 704.1
Data version: 20070422
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E12A273556 Mileage: 69410km/43129miles
Address 01: Engine Labels: None
Part No SW: 8E0 909 557 E HW: 8E0 909 057
Component: 2.0L R4/5VS 0003
Coding: 0011581
Shop #: WSC 63351
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: None
Part No: 01J 927 156 CR
Component: V30 01J 2.0l 5V RdW 2011
Coding: 00001
Shop #: WSC 63351
Address 03: ABS Brakes Labels: 8E0-614-517.LBL
Part No: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04279
Shop #: WSC 06435
Address 08: Auto HVAC Labels: 8E0-820-043.LBL
Part No: 8E0 820 043
Component: A4 Klimaautomat 1012
Coding: 00000
Shop #: WSC 63351
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
Part No: 8E0 907 279 C
Component: int. Lastmodul RDW 0203
Coding: 00001
Shop #: WSC 63351
Address 15: Airbags Labels: 8E0-959-655-84.LBL
Part No: 8E0 959 655
Component: Airbag 8.4E 5001
Coding: 0011602
Shop #: WSC 63351
Address 16: Steering wheel Labels: 8E0-953-549.LBL
Part No: 8E0 953 549 F
Component: Lenks?lenmodul 0308
Coding: 00001
Shop #: WSC 63351
Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
Part No: 8E0 920 900 HX
Component: KOMBI+WEGFAHRS. RB4 D29
Coding: 02000
Shop #: WSC 00010
WAUZZZ8E12A273556 AUZ6Z0B0028825
Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
Part No: 8E0 959 433 T
Component: Komfortger? T5B 0619
Coding: 06858
Shop #: WSC 77300
Part No: 8E2959802
Component: T?steuer.FS BRM 0002
Part No: 8E2959801
Component: T?steuer.BF BRM 0002
Part No: 8E0959801A
Component: T?steuer.HL BRM 0002
Part No: 8E0959802A
Component: T?steuer.HR BRM 0002
3 Faults Found:
01134 - Alarm Horn (H12)
49-00 - No Communications
01616 - Signal Wire to Interior Monitor
49-10 - No Communications - Intermittent
01366 - Opened Due to Crash Signal
35-00 - -
Address 56: Radio Labels: 8E0-035-1xx-56.LBL
Part No: 8E0 035 186 L
Component: concert II GRO 0001
Coding: 00003
Shop #: WSC 77300
Address 76: Park Assist Labels: 8Z0-919-283.LBL
Part No: 8Z0 919 283 A
Component: Parkingsyst. A4 RDW D07
Coding: 01104
Shop #: WSC 63351
End --------------------------------------------------------------------------------------------------
Normally you will find necessary logins and security access codes in the factory repair manual or the VAG-COM documentation.
P.S.: You may want to update your VAG-COM version, current data version 704.1 @ 20071016.<ul><li><a href="http://www.ross-tech.com/vag-com/download/current.html">http://www.ross-tech.com/vag-com/download/current.html</a</li></ul>
