What would be causing this?
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-00
Just to let you know I had to remove the negative supply to the battery while I had my ECU sent to APR for a reflash. When I put back my ECU and power this is the only code that won't go away.
Is it something that will go away after I drive the car for a little while? I think this might be the case because I believe it adjusts itself, but I'm not sure.
Let me know what you think?
