VAG-COM Discussion
wierd connection problem...i can connect fine to some modules but not others.
Old Apr 25, 2007 | 05:16 AM
ModifiedA4's Avatar
Banned
Default wierd connection problem...i can connect fine to some modules but not others.
2000 A4 1.8t, factory radio.
in the past with my setup ive been able to connect with all control modules, for the last year or so ive been really only connecting with the ECU. Logging, clearing codes all is ok.
the communications "options" are set to default.
version 3.11 with an oldschool dumb adapter.
just last night i tried to connect with other modules.
engine: ok
radio: ok
a/c: intermittant with garbled text
instuments: no, vag-com reports "unknown" protocol
abs: no
obviously the interface works in some capacity(engine,radio connects fine). i tried connecting with the car off, key in, and car on...to no avail.
-is it the car?
-the options settings?
-the laptop?
thank you for the help!
Old Apr 25, 2007 | 05:29 AM
Andy@Ross-Tech's Avatar
Banned
Default Tried these suggestions?
<ul><li><a href="http://www.ross-tech.com/vag-com/faq_2.html#2.5">http://www.ross-tech.com/vag-com/faq_2.html#2.5</a</li></ul>
Old Apr 25, 2007 | 05:42 AM
ModifiedA4's Avatar
Banned
i will try this tonight...thanks!
Old May 4, 2007 | 09:18 AM
ModifiedA4's Avatar
Banned
Default no dice...i even reinstalled win98, fresh. the data rate when i connect to the engine seems to have
gone up though. is this really an communications issue or could there be a car side issue?
Old May 5, 2007 | 05:24 AM
Uwe@Ross-Tech.com's Avatar
Banned
Default Hard to say.
ABS OK? I.e. no ABS light? Failing ABS modules of that vintage are infamous for doing strange things to the comms. Try disconnecting the ABS controller -- if that clears up the communications with the other systems, well..
What kind of interface are you using?
-Uwe-
Old May 6, 2007 | 07:38 PM
ModifiedA4's Avatar
Banned
Default i do have a toasted ABS computer...ill try unplugging that! why didnt it think of that? :)
im using 3.11 with a dumb interface. its worked for years, and i know i've connected with the other modules before...though i have not tried for awhile until recently, and quite possibly since the ABS computer started acting up.
Old May 7, 2007 | 03:22 PM
ModifiedA4's Avatar
Banned
Default you are a god! all is well, i unplugged the ABS computer and everything is working great.
thanks for the suggestion!
audifield1
Nov 23, 2010 02:38 PM
ChucktownS4
11
Jan 30, 2009 10:30 AM
OCA::DIY Motorsports
VAG-COM Discussion
Jan 20, 2009 10:24 AM
jesterekim
Dec 19, 2007 05:27 AM
