VAG-COM Discussion
WOT Indicator and wrong factory coding.
Old May 27, 2003 | 04:03 PM
agw2's Avatar
Default WOT Indicator and wrong factory coding.
I just recoded the Instrument cluster to turn off the low level windshield fluid and I found out that my original code was for a NON turbo engine (07242) According to Ross-tech page it should have been (07244). I went ahead and recoded as 03244; the low fluid light is gone and I don't see any problems. Maybe it also fixed the lack of WOT indicator..I'll know tomorrow as I'm too tired to go out now.
Uwe could you confirm that the indication on your web page is correct as follows:
Look at the fifth digit in the coding (Distance impulse multiplier):
0 - TDI Engine (non-USA models)
2 - Non-turbo Gasoline engine
4 - Turbocharged engine
Thanks
Old May 28, 2003 | 03:37 AM
agw2's Avatar
Default Reply courtesy of Dan
In my manual for that last digit of the coding, it only lists 0 for TDI engines, and 2 for gas engines, 4 and 6 cylinders.
On the newer cars (1999.5 up), there is a 4 setting for Turbo engine, but not for the pre 1999.5 cars. I would leave the last digit as a 2.
Old May 28, 2003 | 03:39 AM
agw2's Avatar
Default 1999.5 Mix
My car is 1999.5 but as you know it looks like only some parts are from 1999.5 while others (like the instrument cluster) appear to be from prior to 1999.5.
So you say leave it as 2...ok I'll try a few days with the 4 and then I'll switch back to 2.
Old May 28, 2003 | 01:36 PM
Audi_RKT....(Bedros)'s Avatar
thanks for the info
gm56
Q7 MKII Discussion
18
May 4, 2017 04:05 PM
twlai
A4 (B9 Platform) Discussion
Sep 25, 2016 05:55 PM
DM-S4
16
Jan 11, 2007 02:43 PM
Pushbutton_auto
Jul 7, 2006 06:30 PM
rocketaudi
Sep 29, 2002 02:20 PM
