Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Screw in tire....is it patchable?
Old Aug 28, 2002 | 05:13 PM
Andy_FL's Avatar
25 Year Member
Default Screw in tire....is it patchable?
<img src="http://www2.arkansas.net/~geeare/screw1.JPG">
<img src="http://www2.arkansas.net/~geeare/screw2.JPG">
Argh, and these are brand new tires. :-( What do you think? Thanks
Andy
Old Aug 28, 2002 | 05:20 PM
AJLa4's Avatar
Junior Member
Default not in that spot, sorry, too close to sidewall. you need a new one.
think of it this way, because the tires are new, at least the tread wear on all four tires will be close to even, for what that's worth.
Old Aug 28, 2002 | 06:15 PM
Tbandido's Avatar
Junior Member
Default I would take it in and pull the tire to see if hole is in the...more
If the hole is in the center belt section. If it is...a good tire shop may be able to safely patch the tire. It actually does not look like it is the sidewall, and I bet it would be safe to patch, but you might not know until it has been dismounted. Good luck.
Old Aug 28, 2002 | 08:15 PM
goku's Avatar
Member
Default probably not.
if they can patch it, DONT drive with it on the track.
Old Aug 29, 2002 | 04:44 AM
Eddie@Tirerack's Avatar
Member
Default Nope. Not on the shoulder...
Unpatchable at that point, and ill advised if you could since the shoulder takes the brunt of the handling work on a tire.
Call me if I can help you with a new one..
Old Aug 30, 2002 | 06:36 AM
George Burdell's Avatar
Senior Member
good reason to get some road hazard coverage
Old Aug 30, 2002 | 06:45 AM
Pelican Pete's Avatar
Default A patch won't hold on the corner. You might be able to plug it until a replacement arrives.
A patch will definitely not hold on the corner of the tire. The tire needs to be replaced, no question about it.
You might be able to plug the tire just to get you around until the replacement arrives. However this is NOT a long-term solution, and the tire should not be trusted with a plug.
If the tires are brand new, can you put in a claim with your credit card's buyers security program?
Look at the bright side -- your tires are new so you can just replace one of them. If they had lots of wear on them, you would have to replace at least two of them, and perhaps all four.
Cheers,
Peter
Old Aug 30, 2002 | 10:49 AM
90quattrocoupe's Avatar
Default It is patchable.
Get one of those patch kit, rope type with the glue. Get the black one. Available from AutoZone etc. Make sure you get the glue with it.
Deflate the tire. Unscrew the screw. Put the rope through the eyelet(you will understand when you get the kit), coat the rope with a lot of glue, insert rope into hole, just enought so it goes through leaving excess rope outside,pull eyelet out, and let the tire set overnight.
Cut of the excess rope sticking out of the tire with razor blade. Inflate tire, put wheel on car and run it. Check pressure every day for week.
I have run mine repair for 4000 miles including auto-x and it still holds pressure.
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 30, 2002 | 11:44 AM
Default That sounds more like a plug than a patch.
Yes it will work. But these are meant as a temporary fix only and should not be trusted as a long-term solution.
--P.
Old Aug 31, 2002 | 11:23 AM
Andy_FL's Avatar
25 Year Member
Default Thanks..
..I've got 3 spares, all with tires, so I suppose I'm not in a hurry. :-) I actually picked these up off eBay...$400 for the set...so I can't turn to the CC company on this one. I guess I'll start looking for a new one.....ouch. Thanks ..
Andy
