Section Width vs. Tread Width
Section width is the cross section of the tire and Tread width is the width of a cross section of tread?
If so, what is the tread width on the Kuhmo 712 205/40/17?
Thanks
Tread width is what it sounds like what it is.
Section with is tread width plus bulging out sidewalls plus rim protectors, etc.
<img src="http://www.tirerack.com/tires/images/tiretech/tire_dimen.gif">
<small>Image courtesy of TireRack (hope you don't mind, Eddie).</small>
Section width is affected by the width of the rim. On a wider rim, the tire section width will be larger because the tire gets stretched out more.<ul><li><a href="http://www.tirerack.com/a.jsp?a=AR4&url=%2Ftires%2FSpec.jsp%3Fmake%3DK umho%26amp%3Bmodel%3DECSTA%2BSupra%2B712">Kumho Ecsta Supra 712 Specs from Tire Rack</a></li></ul>
