Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
tire interference
Old Aug 31, 2000 | 01:36 AM
kcS4's Avatar
Junior Member
Default tire interference
Just installed Birdgstone RE730 235 45 17 on Stock S4 rims, getting some rubbing when turning on the right rear only. Any ideas if this should be happening, any ideas on what I can do to cure it other then buy new tires. Seems to be rubbing onthe upper control arm, can see no rub marks on tire though.
Old Aug 31, 2000 | 03:30 AM
Tampa Mike's Avatar
25 Year Member
On a S4? Is your car slammed?
Old Aug 31, 2000 | 03:42 AM
kcS4's Avatar
Junior Member
Default Re: On a S4? Is your car slammed?
no, suspension is stock, 15,000 miles, good alignment just replaced 040's with these and have this rubbing problem
Old Aug 31, 2000 | 06:48 AM
CraigB's Avatar
AudiWorld Expert
Default I know others have done it, but...
235/45-17 is .65" bigger in diameter than 225/45-17. Some of the suspension parts are already close with the stock tires, so any increase in size (diameter or width) could create a problem.<p><a href="http://www.users.uswest.net/~craiger/a4main.htm">
<img SRC="http://www.users.uswest.net/~craiger/cwb_ottosig.jpg" BORDER=0></a>
Old Aug 31, 2000 | 06:55 AM
PSS  //  Raj's Avatar
Default I think the problem is that you should have gone 235/40/17's instead of 45. Check out donP's website
He has a section on his plus-zero tire upgrade.<p>APR V.3 ECU,GIAC Tip Chip,Remus Sport Exhaust,Audi Eurosport Springs,S4 17" Avus Wheels,SmarTire System,LLTek Hex Grille,LLTek Air Induction Kit, Foliatec Red calipers,Camco Aluminum Sport Pedals,Clear Corner Mod,Fog Light Mod,S4 Wheel Well Liners,Ni<ul><li><a href="http://www.audizone.com">http://www.audizone.com</a</li></ul>
Old Aug 31, 2000 | 06:58 AM
MarkFank's Avatar
Default I am running 235/45/17 Yokohama AVS sports w/ no problems. There are on a 17x8 wheel however.
<p><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/Rebadged3.jpg">
Old Aug 31, 2000 | 07:15 AM
CraigB's Avatar
AudiWorld Expert
Default Plus your offset is lower than the stock wheels, right?
Old Aug 31, 2000 | 08:22 AM
kcS4's Avatar
Junior Member
Default Re: I know others have done it, but...
when is I used the tire calculator in the link I came up with :
225/45-17 diameter 25.o inches
235/45-17 diameter 25.3 inches
235/40-17 diamter 24.4 inches
Others have used 235/45 but they put int on a wider 8 or 8.5 inch rim which for sure stretches the tire differently.
Oh well, at least the RE730 is a great tire, should be able to sell these to someone and buy the 40 series or go back to 225/45
Thanks for everyone's help
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 31, 2000 | 08:30 AM
CraigB's Avatar
AudiWorld Expert
Default Oops...my math was wrong...
225/45 = 24.97" dia
235/45 = 25.32" dia
I subtracted wrong in my head (...duh). The difference is .35". I think the problem is the offset. Most people running wider tires probably have aftermarket wheels with a lower offset (wheel sits further out).<p><a href="http://www.users.uswest.net/~craiger/a4main.htm">
Old Aug 31, 2000 | 08:49 AM
MarkFank's Avatar
Default Not sure. Gary @ Ronal - what is the S4 wheel offset compared to the Ronal LZ's?
