Tire replacement?
Since these are expensive-ish tires, I want to take full advantage of the warranty coverage. Will it really make a difference at this point in the season to have one tire that is an all season and the others summer tires. I don't have anywhere to store winter/summer tire packages, nor the money.
Should I insist on the all season replacement or go with the summer tire? I need to push this issue either way today. They have my car and are searching the city for a summer replacement tire so I need to let them know asap if I want them to get an all season tire instead.
Thanks for any advise!!!!
Your Audi dealership or a tire dealer would certainly advise against mixing summer performance tires with an all-season tire. It could possibly result in dangerous handling.
I am in Minnesota where there is a long Winter driving on ice and in snow. I have dedicated wheel/tire setups for Winter and Summer.
It is always disappointing when you have a single tire requiring replacement when the other three are halfway thru their wear cycle. One solution I have used in the past is locating a used tire that is identical to the other three. The solution takes some luck finding the exact same tire you already have on your car.
