Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Vibration problem.
Old Sep 13, 2009 | 12:45 PM
jkownz's Avatar
Default Vibration problem.
Got some new wheels on my Audi A4 and hade them bored out to 66.6. problem is when I put them on I see a gap approximately 1-2 mm gap. When I put them on, the wheel was able to wobble a little bit and had to hold up the wheel to get in 1-2 bolts. This could lead to vibrations right?. Steering wheel and whole car starts to shake around 55+ 70+ its getting real bad. I already had them wheel balanced and wheel force balanced.
Old Sep 18, 2009 | 05:00 PM
AnthraciteCoupeGT's Avatar
I assume you have a B8 chassis with the 66.56 mm hubs. If your wheels were bored out and you still have a 1-2mm gap the shop must have bored them too large, you want a pretty snug fit maybe .1-.2mm of clearance at most. Your vibration is most likely the wheels being off center due to the sloppy fit, not sure if that can be cerrected eaily though, I'd ask the shop if there's anything they can do, I'd be a bit upset with them if I were you though.
poe_a4
Q5/SQ5 MKI (8R) Discussion
Sep 20, 2012 09:19 PM
red4kcsq
Quattro: Turbo / Ur / Sport
Nov 30, 2005 08:07 PM
Quattro 88 80
Apr 14, 2004 08:48 AM
GreyTurboA4
Nov 20, 2003 03:54 PM
Blue DevilS4
Apr 12, 2002 05:31 PM
