99 1.8t turbo surge/stall??
Old 10-20-2014, 09:47 AM
md_medic's Avatar
Default 99 1.8t turbo surge/stall??
I have noticed recently that between %75-WOT (according to vag-com my throttle only opens %86-87 at WOT) the car cuts in and out. For example today I was going up a moderate incline at 60-65mph in tiptronic 5th gear. When the boost pressure guage indicated around 10psi it cut back to 1-2psi and then back up. It did this about 6-8 times then I looked down and it indicated 15boost when it stopped (I have had it to 17psi and normally it just cuts in and out or it will kick down a gear). I have a stock airbox that has been modified by smoothing out the interior and cutting out the bottom with a panel k&n, 3"test pipe to a 3" exhaust, aftermarket turbo inlet, front mounted intercooler, and speed tuning stage II chip. I have gotten the following off vag com in the past two days on two occasions:
17963 - Charge Pressure
P1555 - 35-00 - Maximum Limit Exceeded
17544 - Fuel Trim: Bank 1 (Add)
P1136 - 35-00 - System too Lean
17658 - Fuel Level too Low
P1250 - 35-00 -
Readiness: 0000 0000
16806 - Main Catalyst; Bank 1
P0422 - 35-00 - Efficiency Below Threshold
I do have the stock and I am assuming original diverter valve. Anyone with any ideas and or what to look for on vag-com would be greatly appreciated. This is my first go around with forced induction (2 x MKIV VR6's , 16v MKII, 78 diesel rabbit, and a ration of aircooled) and all of these extra hoses make my head spin. Thank you in advance.
Old 02-11-2015, 06:43 PM
x19
x19's Avatar
Hi, did you find an answer for all problems on your car?
I'm so curious about them and I hope you drive car now or? x19
Mesa512
S4 (B8 Platform) Discussion
20
07-07-2018 11:23 AM
smiladon
10-01-2015 01:31 AM
Eurylo
09-28-2015 04:36 PM
S4Q04
TT (Mk3) Discussion
09-28-2015 07:20 AM
mxp
09-26-2015 10:15 AM
Quick Reply: 99 1.8t turbo surge/stall??
