OIL leaks driving me nuts
Old 07-17-2016, 08:56 AM
  #11
One
One's Avatar
Originally Posted by haraldpost
What is the "VAP" method for changing the valley pan gasket?
No idea- I think there is only one way unless you use magic.
Old 07-17-2016, 09:05 AM
  #12
One
One's Avatar
What about checking the crankcase ventilation? I think it is known to get clogged up, and if it is, pressure can build and result in oil leaks, pushing oil past simrings etc.
This is my suspicion also. I may have a leak at the head gasket, but what is clear is that it is much worse when I drive at higher rpm. I am actually leaving a smoke trail now. I might need to put a warning sticker on my bumper to advise motorcycles of my massive oil loss.
Either the oil is leaking due to oil pressure overcoming the seal or because crank- case pressure is elevated due to faulty ventilation. I did check the breather hoses and they are clear. I must now source a new pcv valve or whatever audi calls it. I do not seem to have excessive engine blow by.
Old 07-17-2016, 10:55 PM
  #13
CRAZY_RUSSIAN's Avatar
on the 2.8, there is not PCV valve. get a pair valve cover gaskets, take off your valve covers and wash them with high pressure and detergent. or you can try soaking them in a solution of simple green and water, rinse them really well, reinstall with new valve cover gasket and torque the bolts to spec.
but you might have other issues.
Old 07-18-2016, 03:34 AM
  #14
haraldpost's Avatar
When installing valve cover gaskets, ensure that mating surfaces are clean and bright.. Use brake cleaner. Sand paper P400-600. Be sure to use an (O2 sensor safe) gasket sealant on crevice on each side of the front and back cam cap. I've done mine for the second time now. I've done seal rings on camshafts and crank pulley. I'm on the 3rd seal ring on one side. I had some trouble with a small scratch in the camshaft, so this time I swapped the camshaft.
Old 12-27-2016, 04:51 AM
  #15
eced1305's Avatar
Default oil leak
Hello, I have an Audi A6 3.2 Quattro with oil outlet under the intake maniford, someone could help me with this ...
Old 12-27-2016, 07:45 AM
  #16
Rusty Spokes's Avatar
Your engine is a later evolution of the V6 12v..try the 30v V6 Motors crowd here: 30v V6 Discussion - AudiWorld Forums
Carlo555
06-21-2008 05:18 PM
radron26
08-02-2007 06:05 AM
bigdom
12v V6 Discussion
09-17-2006 07:45 PM
Beemer832
30v V6 Discussion
03-04-2006 07:44 PM
2Turbos1Love
06-30-2004 05:29 PM
Quick Reply: OIL leaks driving me nuts
