2010 Audi A4 2.0t misfire
Old 04-07-2016, 06:43 AM
belgradeperformance@yahoo.com's Avatar
Default 2010 Audi A4 2.0t misfire
Hoping to find a little help, 10 Audi A4 2.0t codes are P050600, P030100,p030200, p030300, p130a00, and p03000, changed plugs they where carbines up really badly with white powder, test coils all good. Tested fuel pressure from tank 48lbs. Tested for vacuum leak none found. Car does not start hard so not suspecting high pressure pump. Has anyone had similar issues ? Suspecting injectors but don't want to just keep throwing money at it, maybe someone has an idea. Thanks
Old 04-11-2016, 05:50 PM
Prospeeder's Avatar
Crankcase vent valve. Try removing the oil cap while its running. If you cant take off the cap, because theres so much suction, the vent valve is the issue. Sounds like a big air leak to me. Go to live data and watch the short term fuel trim, is it trying to add like crazy, like +25% thats it compensating for a lean condition.
Old 05-28-2016, 06:57 PM
transman's Avatar
Good info posted above. You definitely have false air coming in somewhere.
one place I find a common leak on these is the rear main seal pulling in false air. Its worth calling around to get a smoke test because there are some crazy places these cars can leak.
hope this helps, Connor
crono35
20
11-20-2014 04:25 PM
cparke
06-11-2008 07:06 AM
A4driver1point8
04-01-2008 11:58 AM
euroshowoff
04-10-2007 01:36 AM
WestTennGuy
09-29-2003 07:13 AM
Quick Reply: 2010 Audi A4 2.0t misfire
