High pressure fuel pump fail
Old 06-28-2014, 06:09 PM
TheRoberto's Avatar
Default High pressure fuel pump fail
What are the symptoms of a high pressure fuel pump failure?
Old 06-28-2014, 07:39 PM
TheRoberto's Avatar
Anybody? I'm looking for any info on either hpfp or lpfp or even g247 low pressure sender failure I'm afraid my car is about to die and want to know if it will at least keep limping until I can get it somewhere to fix it. Seriously anything please!
Old 07-16-2014, 03:33 PM
16vsilverstreak's Avatar
Roberto, Check out this thread https://www.audiworld.com/forums/sho....php?t=2867338
I bought the A4 damaged. The previous owner said it was running fine until he noticed smoke coming out from under the hood after the cam follower failed and blew a hole in the cam cover. It is possible to not have any symptoms and have a failed HPFP follower. If you suspect a failure and are past the 120k mark I would stop running the engine until you can verify the follower.
Saileon8
New Member Welcome Area
05-02-2017 12:43 PM
TheRoberto
A4 (B7 Platform) Discussion
06-30-2014 05:40 AM
TheDroid
05-16-2011 05:59 AM
Tanner
Canadian Discussion
12
02-06-2009 08:04 PM
Shep 1.8T
09-17-2006 01:36 PM
Quick Reply: High pressure fuel pump fail
