Any Easy Way to Check Fuel Pressure Regulator ( FPR)?
Old 06-19-2014, 12:05 PM
aTOMic's Avatar
Default Any Easy Way to Check Fuel Pressure Regulator ( FPR)?
I rented the kit from O'Reilly's and none of the provided fittings would fit. It was a brand-new kit and had all the indicated fittings.
I checked at the FPR on the vacuum line, with the engine running and at idle it's pulling 20-23" vacuum... but when I d/c the line the zero vacuum does nothing to the idle. The FPR holds vacuum fine, and there is a relatively steady 20-25 which changes to 5-15 as you rev the car, like it should. Also pulling 30" with a mity-vac does nothing at idle.
If I d/c the FPR and plug the line would the engine throw an additional code, or would I just burn a hole in a piston?
Thanks for advice.
Tom
PS Trying to cure P1130 , P1128 (fuel trim, system too lean, intermittent). one is bank 1 other is bank 2
jackcarrozzo
04-06-2013 12:43 AM
Redneck Truck
04-07-2011 07:25 AM
cparke
12-05-2008 07:06 AM
VAP
12v V6 Discussion
10-06-2008 01:03 AM
moribundman
12v V6 Discussion
07-07-2004 04:07 PM
Quick Reply: Any Easy Way to Check Fuel Pressure Regulator ( FPR)?
