Old/compressed gasket on PCV causing oil leak??
Old 02-04-2017, 01:22 PM
markrQ7's Avatar
Default Old/compressed gasket on PCV causing oil leak??
I have a 2007 Q7 4.2FSI with 70k miles and in the past few months, I've been churning through half a quart or more every tank of gas. The indy shop replaced the oil pan gasket for $1250 but it didn't solve the problem. I found many videos showing that the oil filter housing gaskets can be a huge problem so I figured I'd be in for another $500-$1000 job. In my case, I used a long lead USB camera to check the bottom of the oil filter housing and it's very clean down there. So I bought a new PCV valve (by the way, mine was covered in oil) and when I took it off I noticed how much play there was at the gasket by the pressure limiting valve where it attaches with two torx bolts. Comparing the new PCV and its gasket to the old one was like night and day -- the new red gasket was maybe 3 times thicker than the 10yr old one. I think the bad seal was allowing air to enter the system at that point and the whole crankcase ventilation system was no longer working -- the PCV was not depressurizing the crankcase. My oil was sludging up and there was no sign of fresh oil going down the flex tube that attaches to the bottom of the PCV (below the fine oil separator) -- that tube was totally dry. And I think that was allowing too much pressure in the crankcase which ended up pushing oil past the pan gasket. Should be a few days til I know for sure (we'll see it on the garage floor!), but it makes the most sense to me. Even the new oil pan gasket ($1250 wasted) is wet again which tells me the system was not working. Hope this fix works.... if it does not, perhaps that tube below the fine oil separator is clogged? If that's not it, I'm starting over.
Old 02-08-2017, 04:03 PM
markrQ7's Avatar
Replaced the PCV and am still leaking. So, everything I wrote above is bologna. I thought I could see the lower part of the oil filter housing and that it was clean, but I just put the USB camera into the weep hole on the front of the engine where I thought it was leaking from, and sure enough, there is tons of oil just sitting in there between the cylinder banks under the intake plenum. Ugh. Off to the indy shop to replace the oil filter housing gaskets.
Old 04-12-2017, 03:02 PM
aTOMic's Avatar
Wow, sorry for the bad initial diagnosis. What's happened since? I think they need to put a pop-off valve in the PCV system on these to prevent this.
Tom
everest1
01-31-2008 01:49 PM
lemond33
10
12-31-2007 09:27 AM
kanefire222
12
12-19-2006 09:33 AM
bigdom
12v V6 Discussion
09-17-2006 07:45 PM
2Turbos1Love
06-30-2004 05:29 PM
Quick Reply: Old/compressed gasket on PCV causing oil leak??
