99.5 2.8 V6 Overheating + heat blows hot+electric cooling fan is off =t-stat or CTS?
Hi
I have a 99.5 A4 2.8 with 139k.
TB job with TB KIT was done by me at 97k in 2011 (Timing Belt, Water Pump(GRAF), T-stat(BEHR 87c) and all rollers from TB KIT + New heater core)
Everything was fine but Today 40k later I see that:
-Engine overheat (water temp gauge go past the middle..a notch) VAG readings shows that temp is going up from ~90 to 114c and beyond
-Electric cooling fan does Not turn on even at 114c, BUT if I turn on the heater it start to work/spin.
-Heater blows very hot air
-Radiator was replaced in 2010
-coolant Level is fine (just checked)
Is it Thermostat that stuck Closed or Coolant Temperature sensor top or bottom (back in 2007 at 73k both sensors was replaced) ?
Anything else I can test?
....I cant drive now because its overheat very fast.
Thanks!
Thanks!
When the engine gets to normal operating temperature, check to see if both the top and bottom radiator hoses are hot. If the bottom one isnt nice and hot then the thermostat is not opening to allow the coolant to circulate.
VR_Life
Audi Original "S" Cars
06-18-2005 02:59 PM
Audi Junkie
17
08-06-2003 08:03 PM
