A4 (2001) Rear Window Regulator Replacement (lengthy)
Old 05-15-2012, 06:06 AM
  #11
vtraudt's Avatar
I don't know the actual dimensions of the pulley; only similar one I currently stock is part of the 'corner pulley' as I call it (used in several Audi models). Left and right version shown below.
-regulatorfix
Originally Posted by nidreu
I'm having the same problem with my windows. I removed trim and what not, and think I found the problem.
The white part in the attached image is broken. Does anyone know the name of the part, and where I can order it from?
Thanks and take care.
Old 05-15-2012, 09:06 PM
  #12
skiingman's Avatar
I wish I had seen this earlier...just did this on one of my rear windows. Does anyone know what grease is recommended for the regulators? The old grease in mine was more like abrasive compound with all the dirt it had taken on. When I'm bored I plan to take apart the other three doors and clean and relube each.
Old 05-16-2012, 02:25 AM
  #13
vtraudt's Avatar
Default Lube Grease
White lithium grease is what I am using
Old 06-11-2016, 11:45 AM
  #14
ClickX2's Avatar
ThreeDogsA4 -
I want to thank you so much for your very thorough posting on this subject of the window regulator. I have a very well maintained 2002 Audi S4. I had an issue with the RR window. I took the door panel off and could see the top white plastic pulley had shattered. Broken pieces were in the bottom of the door. Audi wanted an exorbitant price for the regulator. I bought one online from 'part out' B5 for $69. I followed your directions with pictures step by step, and everything went well. A great and very helpful posting. Thank you very much.
Old 10-14-2016, 08:56 AM
  #15
tobyo123's Avatar
Quick question - the original poster noted that the holes for the motor bolts weren't tapped out - anyone else come across this? I've just received my replacement regulator and see the same, but am wondering if I actually need to tap them or if they will self-tap. I don't really want to destroy a bolt in order to find out.. Thanks!!
beep-beep
Audi 100 / A6 (C4 Platform)
01-12-2022 08:57 PM
Trent
09-15-2006 10:51 PM
eurolussions
08-11-2006 06:43 PM
lunamar
01-22-2006 08:41 PM
nick n
05-15-2000 06:51 AM
Quick Reply: A4 (2001) Rear Window Regulator Replacement (lengthy)
