Audi A4 96 - Climate Control Display Problems
Old 08-18-2000, 10:56 AM
New Member
Audi_all_the_way's Avatar
Default Audi A4 96 - Climate Control Display Problems
My Display has been flickering in and out randomly for the past of couple months. I was wondering if anyone else was experiencing this same problem. When I go over a bumpy road or when I press the +/- button on the temp or on the fan side sometimes the display will come back and stay for a while. However sometimes it disappears completely and I can't tell what temperature I have the AC set to. It's quite annoying.
Old 08-18-2000, 11:46 AM
Longwolf (Christian)'s Avatar
Default bulbs or wires
Pull out your Climate Control panel, and WD40 all the wire connections between the unit and the wiring harness, and then check the bulbs....better yet, if you are going through all the trouble of pulling the unit out, replace the bulbls while you are there.
I have never taken one of these units out, but I figure that it as the standard Audi style wiring harness and bulbs.<p>Christian J. Long
President - Quattro Club of Florida
Orlando, FL
'00 A4 1.8tqsm
'97 A4 1.8tqm
'87 944S
Past Audis:
84 CGT, 85 CGT, 87.5 CGT, 90 CQ
98.5 A4 1.8tsm
Old 08-18-2000, 01:15 PM
New Member
2003 Dolphin A4 3.0Q's Avatar
Default My 97 use to flash at me. I had it replaced under warrenty. My dealer said it was a short.
It would get bright red.
Old 09-04-2000, 03:07 PM
New Member
RBHansen's Avatar
Default Re: Audi A4 96 - Climate Control Display Problems
I've had a similar problem on my '96 A4 (75K miles). Display flickers, sometimes is out for a while, and sometimes works for a while.
I've also had the sporadic sunroof open/close problem and just last week my odometer display went out (but now it's back).
Anybody have thoughts on whether all of these electrical glitches are tied back to the control unit or should I try replacing the bulbs and checking the connections on the display (although this won't fix the sunroof).
Old 07-26-2015, 10:43 PM
runaway's Avatar
This is a common problem with this model. I saw some youtube video on this how to fix.
TheJohnsons95
08-15-2000 04:11 AM
mmike
08-08-2000 08:32 AM
sa-a4
06-21-2000 07:28 AM
miker
Misc. Models Discussion
06-20-2000 02:41 PM
A4 FL2
06-07-2000 08:54 AM
Quick Reply: Audi A4 96 - Climate Control Display Problems
