A4 B5 Alternator / IGN / car wont stop probem
Old 10-19-2013, 04:03 AM
smee3041's Avatar
Default A4 B5 Alternator / IGN / car wont stop probem
1996 Audi A4 B5 1.8T saloon UK Spec. Had a fire in the door drivers (now disconnected all loom pending fitting a replacement) I replaced damaged wires in loom running alongside the drivers door. Now car starts (all ECU functions seem good) but car won`t turn off on ignition key (so I stall and then disconnect battery to stop noise coming from throttle body) and to make ignition light go off. Auto electrician said its either short in dash wiring loom or maybe diode problem with the alternator.
Before I go round to the garage and get their assistance to disconnect the wiring to the alternator I suppose I should ask "does anyone know if that alternator fault could "FEEDBACK?" and make a live feed so the engine won`t shut off with the ignition ?"
Any one know ?
Old 11-03-2013, 11:48 AM
smee3041's Avatar
Hmm all the replies to this post seem to have disappeared.
Old 11-03-2013, 08:47 PM
turbo510's Avatar
Any one know ?
No, that can't happen. The diodes in the alternator only serve to rectify the 3-phase AC voltage into the direct current that powers the car's electrical system. A bad diode either fouls up the smooth conversion to DC, or shorts and drains the battery when the engine is not running.
I'd start by replacing your ignition switch before anything else.
carl viking
36
04-27-2020 01:17 PM
N'Syncro
33
02-16-2020 03:12 PM
fkaufman
A7
09-07-2015 07:59 PM
ttedeschi3
09-04-2015 06:48 PM
tvelasquez1
2.0T FSI Discussion
09-01-2015 07:35 PM
Quick Reply: A4 B5 Alternator / IGN / car wont stop probem
