I lost my blinkers - hazards still work - can't figure out where the relay is.
Old 01-22-2008, 06:50 AM
Elder Member
CURSH[silverbullet]'s Avatar
Default I lost my blinkers - hazards still work - can't figure out where the relay is.
STFA and I basically suck at it (searching)
Anyway - the dubbers keep telling me its the 4 way switch in the Hazards button and that it was a recall and a problem in all MKIVs (but of course I don't drive a MKIV do I)
ECS tuning led me to believe that I was going to have to replace my entire control stalk on the steering wheel (highs, lows, blinkers stalk)
Its $130 part that is attached in ways that I don't fully understad at this juncture, so I would rather not order the part without knowing that its the relay.
Not having blinkers is making me paranoid and feel like an *** hole when I drive.
On a further note I think my turbo is on its way out - it holds at 9psi (chipped) but throws no codes - in past experience with vac leaks I would be throwing mass codes by the time it got this bad.
Sucks - but to be sure I'm going to check my lines anyway.
TIA bishes
Old 01-22-2008, 07:10 AM
Elder Member
Default Anyone? I would hate to have to pull my bently out
its under my hardwood floor under everything I own in the back seat of my car.
that would require an afternoon.
Old 01-22-2008, 07:14 AM
jguthrie's Avatar
Default yes it's part of the hazard button
but it could be the stalk too. I think you would need to dig out the bentley pull the hazard and try to test it.
Old 01-22-2008, 07:15 AM
Elder Member
Default hmm - sweet. I think it would be odd for part of the stalk to fail
and have everything else on it work.
like the Cruise Control and such.
Thank you sir
Old 01-22-2008, 07:56 AM
1.8TQ99.5's Avatar
I believe it's behind the center dash, a bitch to get to.
Old 01-22-2008, 08:25 AM
shawfm's Avatar
Default It's not the relay, its the blinker fluid you have been using. Use the synthetic stuff.
<center><img src="http://kalecoauto.com/images/BlinkFluid.jpg"></center><p>Sorry I just really like that explaination. And since you already found the correct answer...
Old 01-22-2008, 09:12 AM
Elder Member
no for real - where can I get this stuff? My blinkers have been blinking like total weaksauce lately
quattro.pilot
Audi Original "S" Cars
16
10-25-2008 06:01 PM
HIS4
01-14-2005 09:20 AM
audiman231
02-16-2004 05:25 PM
SteveAngry
09-22-2003 07:07 AM
Skewoooot
04-08-2002 10:31 AM
Quick Reply: I lost my blinkers - hazards still work - can't figure out where the relay is.
