intermittent no start
Old 08-30-2015, 05:31 PM
  #11
ktleop1959's Avatar
Mine will start fine once twice 10 times a day then for some reason I crank it and its like the battery is only at about 10% with a jump it starts right up immediately and will start again no problem till the next time I never know when it will happen the voltage check when running is 14.2 the battery and cables are new I did notice early on if I lock the doors the battery would drain completely overnight Any Ideas?
Old 08-31-2015, 05:43 AM
  #12
clancy's Avatar
Default not the same issue
I suggest you start a new thread. This is not the same issue.
Old 08-31-2015, 03:31 PM
  #13
ktleop1959's Avatar
I thought I did sorry for that
Old 04-25-2016, 10:34 AM
  #14
snatchman's Avatar
Originally Posted by clancy
Well, problem finally became bothersome. Decided it was one of three likely issues, clutch safety switch, ignition switch, or convenience module in the trunk area. Removed the knee bolster and bypassed the clutch switch. Simply unplugged it and put a jumper in the plug. All of 20 minutes beginning to end. Then I inspected the module in the trunk to see if there was corrosion from water leakage; nothing. Figured if the no start issue continued then I was down to ignition switch.
No longer a problem. Starter engages every time now. Must have been the clutch safety switch. Will report back if the issue comes back.
Thanks for all the suggestions.
Did you ever replace the switch, if so do you have the part number and how hard was it to change? I'm having the same issue with my 2000 A4.
AudierJC
9
01-31-2021 07:20 AM
flippity_01
A4 (B7 Platform) Discussion
11-16-2018 11:58 AM
D3Audi
Q7 MK 1 Discussion
13
01-25-2017 03:58 AM
Fairfax 4.0T
Mid Atlantic Discussion
11
02-13-2008 03:37 PM
rjmnyc
07-30-2007 08:03 AM
Quick Reply: intermittent no start
