After a long time sitting, what should I do?
Old 06-04-2008, 07:58 PM
Junior Member
Mr Paul [T-28]'s Avatar
Default After a long time sitting, what should I do?
My car hasn't been started or run for about a month and a half. I am assuming I should pull the fuel pump fuse and crank it for a while to get the oil circulating. Anything else I should do?
Old 06-04-2008, 08:05 PM
TabulaRasa's Avatar
I would just turn the key and start it.
Old 06-04-2008, 08:09 PM
pointby's Avatar
second
Old 06-04-2008, 10:12 PM
Member
Silver Streakin''s Avatar
Default use the bathroom? get a beer?
I would turn the key to on to see if the battery is even at 12v.
you can do the oil pump trick, if you want, but I agree with the others to just start it. 6 weeks isn't that long.
Old 06-05-2008, 02:59 AM
Tech Guru
4Driver4's Avatar
Old 06-05-2008, 04:39 AM
Banned
CTA4AVANT's Avatar
Quattro
Old 06-05-2008, 04:50 AM
Tech Guru
4Driver4's Avatar
Default If the battery is not on a tender and is dead, charge the battery before you start the car.
Avoid jumper cables if possible.
Old 06-05-2008, 05:17 AM
Junior Member
Done and done. I plan on charging the battery tonight. Thanks.
Nvncibl
12-19-2014 10:42 PM
65fastback
07-12-2012 02:18 PM
markg228
Audi 100 / A6 (C4 Platform)
04-24-2010 04:56 PM
DC_//S4
12
01-10-2008 07:30 PM
thermonuclear
11-12-2001 10:19 AM
Quick Reply: After a long time sitting, what should I do?
