ESP/ABS
Old 08-20-2014, 11:01 AM
cuatronoza's Avatar
Default ESP/ABS
When I turn on key all warning lights are on exept the esp. As soon as engine is running only abs is on with brake light blinking and three loud beeps. Esp button does nothing. I only have vcds-lite to work with. Can't connect to abs controller. On engine controller only one code is present. 18057 powertrain data bus:missing message from abs controller. I checked fuses and the wiring to the esp controller under rear seat and everything is fine.
Old 08-21-2014, 02:52 AM
Tech Guru
4Driver4's Avatar
Did you search? One of the most common problems evAr in this body style.
You need your ABS control unit rebuilt. Search for CheapABS.com, Module Master, or BBA Reman.
R&M
9
10-27-2023 07:55 PM
PhilMason
01-03-2011 02:24 PM
feakara1
Brakes Discussion
07-10-2006 05:37 PM
technics100
06-14-2004 01:02 AM
LCP
09-02-2003 09:50 AM
Quick Reply: ESP/ABS
