What causes tires to cup, and what's the best way to prevent this?? TIA
Old 09-28-2001, 12:39 PM
hellboy's Avatar
Old 09-28-2001, 12:41 PM
EdP
AudiWorld Uber User
EdP's Avatar
Default here...
<ul><li><a href="http://www.autoshop-online.com/cchtml/tire.wr.prob.html">Cupping</a></li></ul>
Old 09-28-2001, 12:43 PM
hellboy's Avatar
Thank you sir.
Old 09-28-2001, 12:47 PM
nick n's Avatar
Default In addition you should..
<u>only</u> push down on the inside of the car, meaning, pop the hood a push over the shock tower. The same goes for the rear.
Member
Silver Streakin''s Avatar
Default sounds like worn out shocks to me...
Cupping is a condition caused by the tire bouncing as it rolls. Small areas of heavy wear are created. Worn shocks are often the cause of cupping, but loose suspension parts or tire imbalance are also possible causes.
Old 09-28-2001, 12:48 PM
hellboy's Avatar
Thanks for the info guys.
Old 09-28-2001, 12:49 PM
Evan (Vogon)'s Avatar
Default I don't have cupping, but I have this...
<img src="http://pictureposter.audiworld.com/17150/tire.jpg">
dealer says I drive too hard...
Old 09-28-2001, 01:06 PM
New Member
The Blizzard of Oz's Avatar
Default If they are Pirelli, they do it automatically
It's the nature of the beast. Otherwise, bad shocks.
Old 09-28-2001, 03:35 PM
Junior Member
Tbandido's Avatar
Default Another option is to make sure no run-out problems exist...
I had a tire problem that caused cupping, not as deep as with bad shocks though. A "good" tire shop can do a load variance balance test to make sure the high spot on the wheel matches the with the low spot on the tire. Sounds confusing, but a perfectly balanced tire my not be rolling round. At high speeds, in my case only 50mph, I would get a slight vibration, not bad, but bad enough to cause cupping on the front tires.
After I had the shop fix the problem, they remounted the tire on a different location on the wheel, it was AMAZINGLY different. It felt like a different car. I had not realized that it was this bad before.
Note, I had my tires balanced 2 times before that, by a different shop and each time they said they were fine.
Anyway, my 2 cents. Good Luck
brat2.ua
RS4 (B7 Platform) Discussion
01-24-2007 03:42 AM
momotoTTe
Wheels & Tires Discussion
06-09-2003 04:06 AM
germinator
01-03-2003 05:35 AM
A4agarwal
08-13-2002 03:20 PM
Le Chef
10-17-2001 09:29 AM
Quick Reply: What causes tires to cup, and what's the best way to prevent this?? TIA
