Intermittent smoke problem
Hello,
We have a 2008 A4 2.0T Audi with 93,000 miles...we are the second owners.
The issue is, about 4 or 5 times in the last year, but especially in the last 3 months, we will be driving and it will start to cut out and then a HUGE plume of smoke comes out the back. Each time has gotten progressively worse. Each time I have pulled over and turned the car off, then restarted it and it was ok. Except the last time, i had to run it about 10 minutes before I was getting no smoke. While this is happening, I can put it in neutral and rev it and its fine(except for the last time). The only common denominator has been it has been on warm days...(75-85 degrees). We have to put a qt of oil in about every other month.
If any one has experienced this, or has any thoughts I would be greatly appreciative.
Thank you,
Tom
Thank you,
Tom
Tom,
I had the same issue last year. Your valve cover probably has a crack on the underside and it is causing oil to spill into your turbo intake and smoke like crazy, especially when you accelerate. You probably also have a lot of oil sitting in your intercooler pipe as a result. Check your valve cover and replace if necessary then drain your intercooler pipe and you should be good to go. It will also help with your oil consumption issue.
QuattroPower88
Audi Original "S" Cars
14
11-09-2008 05:40 PM
Twisted5000
09-04-2004 10:32 PM
