A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
What's the coolest coding setting on a B8?
Old 12-17-2014, 11:54 PM
  #51
Former Vendor
Carista's Avatar
Originally Posted by NawDawg
I have a 2014 a4 and the phone finds the obd reader. but when it starts searching for customizations, the percent never moves from 0%. and then eventually after like 5-10 mins it says it doesn't work. whats the dealio? any suggestions help. thanks
Hi, sorry to hear about the trouble. This behavior is usually a sign that you're using one of those "v2.1" ELM327 devices that seem to be flooding the market nowadays. They're fake and they don't work with Carista. They may work with other apps that only use OBD2 functionality, but Carista uses VAG-specific functionality as well, and those devices don't support it (even though the ELM327 v1.4 standard requires support for the stuff that Carista uses). These devices claim to be v2.1, but they don't even support v1.4 specs.
But to confirm that that's the case, please connect to your car and when the app gets stuck with the spinner on the screen (or shows an error message), use the "Report a problem" button from the slide-out menu on the left to send a technical report through the app. Then we'll be able to see whether the thing I'm talking about above was indeed the cause of the issue.
Note that our links to Amazon link to items, not specific sellers. Different sellers for the same "item" on Amazon may actually be selling stuff made by different manufacturers, and altogether working differently. So one seller may be selling a v1.4 or 1.5 device that works fine and another seller of the SAME ITEM on Amazon may ship you a fake v2.1 device. We have no way of controlling that, so our recommendation is that you look at reviews for specific sellers, not just for the items.
If you're in the US, the BAFX device that we link to seems to get consistently good feedback from our users. It's bulkier, but it seems to work more reliably.
Old 12-18-2014, 01:42 PM
  #52
roger_1's Avatar
[If you're in the US, the BAFX device that we link to seems to get consistently good feedback from our users. It's bulkier, but it seems to work more reliably.[/QUOTE]
Where can I find the link to the BAFX device? Can you post the link here, please?
Old 12-18-2014, 05:08 PM
  #53
Fox Fader's Avatar
if i remember correctly this sounds like the first one that i had. I think mine did the same thing, turns out it was bad the replacement work perfectly.
Try another obd2 app to see if it works ok with that app.
Old 12-19-2014, 12:51 PM
  #54
Buckwheat's Avatar
Originally Posted by Fox Fader
Complete list on my car;
Doors / Windows / Remote:
Auto-lock doors when moving
*YES* / NO
Auto-unlock doors when key is taken out of ignition
*YES* / NO
Auto-lock trunk when moving
*YES* / NO
Beep when alarm is armed
*YES* / NO
Unlock doors via remote
*DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND* / ALL DOORS ON 1ST PRESS
Unlock doors via smart key (door handle button)
Enable settings for opening/closing windows and sunroof
*YES* / NO
Open/close windows and sunroof via long-press on remote
*YES* / NO
Close windows via long-press on remote
*YES* / NO
Open windows via long-press on remote
*YES* / NO
Close sunroof via long-press on remote
*YES* / NO
Open sunroof via long-press on remote
YES / *NO*
Sunroof action when opening via remote
SLIDE / *TILT*
Open/close only driver's window via remote or key
YES / *NO*
Open/close windows and sunroof via smart key
*YES* / NO
Close windows via smart key
*YES* / NO
Close sunroof via smart key
*YES* / NO
Open/close windows and sunroof by holding key in door lock
*YES* / NO
Open windows by holding key in door lock
*YES* / NO
Open sunroof by holding key in door lock
*YES* / NO
Close windows by holding key in door lock
*YES* / NO
Close sunroof by holding key in door lock
*YES* / NO
Close convertible roof via long-press on remote
*YES* / NO
Close convertible roof by holding key in door lock
*YES* / NO
Close convertible roof via smart key
*YES* / NO
Open convertible roof via long-press on remote
*YES* / NO
Open convertible roof by holding key in door lock
*YES* / NO
Blink turn signals when done closing windows via remote
*YES* / NO
Enable remote control when vehicle is running and in gear
YES / *NO*
Instruments / Display / Dings:
Gauge needle sweep at startup
*YES* / NO
Gauge needles lit even when headlights are off
*YES* / NO
Gauge scales lit even when headlights are off
*YES* / NO
Seat belt warning
DISABLED / US/CANADA STYLE / EURO STYLE 1 / EURO STYLE 2 / *EURO STYLE 3*
Lights:
Allow configuring daytime running lights via dash display
YES / *NO*
Use front LED lights as daytime running lights
*YES* / NO
Use fog lights as daytime running lights
YES / *NO*
Use high beams as daytime running lights
YES / *NO*
Use tail lights as daytime running lights
YES / *NO*
Use side marker lights as daytime running lights
YES / *NO*
Use low beams as daytime running lights
YES / *NO*
Dim daytime running lights when ignition and parking lights are both on
*YES* / NO
Turn off daytime running lights ("wink") when turn signal is on
*YES* / NO
Coming-home lights
*ENABLED* / DISABLED
Leaving-home lights
Use fog lights as coming-home lights
*YES* / NO
Use low beams as coming-home lights
YES / *NO*
Turn off front fog lights when high beams are on
YES / *NO*
Turn off rear fog lights when high beams are on
YES / *NO*
Lower headlights for traveling to RHD/LHD country
YES / *NO*
Flash brake lights in emergency stopping
*YES* / NO
Flash hazard lights in emergency stopping
YES / *NO*
Turn on side marker lights with headlights (US models only)
*YES* / NO
"Euro" parking lights when ignition off, turn signal on
YES / *NO*
Other:
Lower passenger-side mirror when in reverse gear (may need memory seats)
*YES* / NO
Remember position when lowering passenger-side mirror in reverse gear
*YES* / NO
How about a setting to turn off the annoying gear shift indicator and associated "economy" tips? Forever?
Old 12-20-2014, 03:07 PM
  #55
BMWBig6's Avatar
[QUOTEClose windows via smart key
*YES* / NO
*YES* / NO [/QUOTE]
What is this referring to? I see settings for these functions with long press of remote but what is the "smart key"? (I have the comfort access btw)
Old 12-21-2014, 04:17 PM
  #56
Fox Fader's Avatar
Turn that off in the mmi
*YES* / NO
*YES* / NO
What is this referring to? I see settings for these functions with long press of remote but what is the "smart key"? (I have the comfort access btw)[/QUOTE]
Old 12-22-2014, 07:47 AM
  #57
BMWBig6's Avatar
[/QUOTE]
OK, I have 2 smart keys like that. But what is this setting talking about? Momentarily pressing the lock/unlock sensor area on the door handle (with smart key in your pocket)? Because there are already remote-specific functions (by long pressing the key fob button)? Or is one talking about the non-smart key (no comfort access) and this one is talking about smart keys only?
Old 12-23-2014, 06:53 AM
  #58
Vdubtx's Avatar
OK, I have 2 smart keys like that. But what is this setting talking about? Momentarily pressing the lock/unlock sensor area on the door handle (with smart key in your pocket)? Because there are already remote-specific functions (by long pressing the key fob button)? Or is one talking about the non-smart key (no comfort access) and this one is talking about smart keys only?[/QUOTE]
If you have coded via Vag-Com, you can close or open the windows via the fob. Can also have the sunroof tilt up or close via the fob as well.
Old 12-24-2014, 12:00 PM
  #59
Macallan21's Avatar
Are there any new features coming to the Audi mods soon?
It'd be pretty cool if I could reset the "service soon" thing on the drivers display.
Old 12-27-2014, 03:35 PM
  #60
Fox Fader's Avatar
I don't have the comfort access so I dont know.
Quick Reply: What's the coolest coding setting on a B8?
