A4 Cabriolet (B6 Platform) Discussion Discussion forum for the B6 Audi A4 Cabriolet
2004 Audi A4 3.0L Convertible Top
Old 03-29-2015, 01:02 PM
Volcar21's Avatar
Default 2004 Audi A4 3.0L Convertible Top
Hi Folks,
I have been having a problem with soft top it will not open and a recent scan of the system reviled the following error code. "Switch Position, Sporadic 008 Implausible Signal" in addition when I activate the roof switch I also receive the following message on my dashboard display "Close Trunk Lid" despite the fact that the trunk lid is closed.
If any of you good folks can advise me on how to correct this problem I will be extremely grateful. Note all comments, suggestions and advice will be greatly appreciated.
Old 04-07-2015, 08:58 PM
ltooz_a6_a8_q7's Avatar
Default Check your switch on the side of the roof (passenger)
to see if it fell out of place.
Make sure the roof pocket is released down 100%.
Check the trunk lock switch, make sure the wires are not out of place which cause the "trunk open".
Check my signature for all the stuff I did with my 04 cabriolet 3.0 which my sister is driving now.
The position sensor is the one you need to check to open and close the top. I'm always in the A8 D3 forum.
Cheers,
Louis
Old 04-14-2015, 12:51 PM
Volcar21's Avatar
Hi Louis,
Thanks for the advice it is greatly appreciated. I will follow your suggestions and advice you of the outcome.
Thanks again, have an awesome week.
Old 05-24-2015, 08:19 PM
Wirewheels's Avatar
Volcar, follow Louis's instructions in his links to dogmonkey - the key is that the top MUST see a complete sequence to get an all clear. I was having this issue today after having the car for a week with no problems, and Louis's instructions were spot on. You'll need to use the special wrench/key hidden with the fuses to lock the tonneau and the header bar to get the top back in to "closed" position. Worked for me!
Louis, you rock!
Brian
GStar
08-08-2018 03:29 AM
Kendra
01-25-2018 06:46 PM
Prof
A4 (B8 Platform) Discussion
04-01-2012 04:38 PM
MarcSavage
05-09-2010 07:40 AM
cnelson
Audi 100 / A6 (C4 Platform)
03-08-2008 06:22 PM
Quick Reply: 2004 Audi A4 3.0L Convertible Top
