Audi A6 TAILIGHTS DECODED
Old 04-26-2014, 09:12 PM
  #21
kdagher's Avatar
Originally Posted by jmgard58
I tried to read and understand this but I got 'lost' at the spreadsheet...so here is my question:
Do 'our' rear fog lights not work and is the only way to make them work to use a VAG-COM and re-wire some leads to the light fixtures?
Thanks!
I am not sure i understand your question, but our rear fog lights do work.. i just identified what is the coding of the channel for a rear fog light. if you apply this code for the channel responsible for the side markers, they will be come rear fog lights when you switched it on..
Old 04-28-2014, 01:38 PM
  #22
Hockenheim's Avatar
Originally Posted by kdagher
I am going to post the Audi A4/A5 codes as well.. Just decided hehe
Old 04-29-2014, 09:48 PM
  #23
kdagher's Avatar
Originally Posted by ekyp
Thanks kdagher!
I tried tackling it a couple months ago on my 2013 A4 and found the Outer lights (EU Signal/Brake lights) are coded as 1 channel in the US. You are right, it's mostly due to the fact we have side market light using the extra channel. Is there anyway we can separate them so the light matches the EU ones?
Unfortunately no, the only way is to open the taillights and replace the circuit.. It's almost impossible to open the tailights without cracking them
Old 04-30-2014, 03:53 PM
  #24
vw754's Avatar
[B]Hi,ive just fitted the rear led(genuine) tails to my b8,now the inner led's dont work when i brake + im getting bulb out errors on the dash,do i have to go to audi for coding or is possible to do it myself? i have full version of vcds (vag-com)
Old 04-30-2014, 03:54 PM
  #25
vw754's Avatar
Hi,ive just fitted the rear led tails to my b8,now the inner led's dont work when i brake + im getting bulb out errors on the dash,do i have to go to audi for coding or is possible to do it myself? i have full version of vcds (vag-com)
Old 04-30-2014, 11:27 PM
  #26
kdagher's Avatar
I need a bit more details thant.. what is your MY ? Did you have halogen lights before LED ? Are you converting to EURO led pre or post facelift ?
PLease post your Channel Values from 181 to 214, i will help you coding them.
Moudle [46] ---> Security Access 16017 ---> Adaptation ---> Read values from 181 to 214 and post them please
thank you
Old 05-01-2014, 06:26 AM
  #27
vw754's Avatar
thank you
ive fitted pre face lift led's off 2010/11 uk model b8 to my 2008 b8 uk model right hand drive.
yes i had halogen lights before.
46-central conv was telling me to enter security access 22790,but i used 16017 as you advised and have taken the following readings.........>
channel 181........stored value 65535
channel 182........stored value 255
channel 183........stored value 16383
channel 184.........stored value 255
channel 185.........stored value 65535
channel 186.........stored value 255
channel 187.........stored value 16383
channel 188.........stored value 1
channel 189.........stored value 16383
channel 190.........stored value 1021
channel 191.........stored value 16143
channel 192.........stored value 3
channel 193.........stored value 6
channel 194.........stored value 7
channel 195.........stored value 10753
channel 196.........stored value 10785
channel 197.........stored value 11268
channel 198.........stored value 11300
channel 199.........stored value 0
channel 200.........stored value 0
channel 201.........stored value 0
channel 202.........stored value 0
channel 203.........stored value 7754
channel 204.........stored value 7786
channel 205.........stored value 13
channel 206......... stored value 45
channel 207.........stored value 12
channel 208.........stored value 44
channel 209.........stored value 0
channel 210.........stored value 0
channel 211.........stored value 51214
channel 212.........stored value 51215
channel 213.........stored value 13360
channel 214.........stored value 3
Old 05-02-2014, 03:56 AM
  #28
vw754's Avatar
kdagher.........hopefully i wont have to go to the dealer,thanks to you if you can sort it mate
Old 05-02-2014, 05:04 AM
  #29
kdagher's Avatar
Since your car is a B8, let's take it up to the personal messages. I sent you a PM
Old 05-02-2014, 05:37 AM
  #30
vw754's Avatar
pm reply sent.......thanks
Quick Reply: Audi A6 TAILIGHTS DECODED
