Cruise control speed limit system
Hi team.
On my audi A7 it says in the equipment list I have Cruise control speed limit system.
Now its one stick and so far as I have been able to work it, its just a basic cruise control, i.e. set a speed and it accelerates to that and stays there.
On my last car, I set a speed and speed limit meant I could hit the go faster pedal, but it would not go beyond the speed I set (Unless I floored it then it would allow me to accelerate beyond the limit. I really prefer this over cruise control, but cannot see anyway to set that.
So is Cruise control speed limit system simply put not that at all and is infact 'Cruise Control'?
Not really. If you set the cruise then accelerate past it and let off it will brake back to the set speed. What car did you have that had two set speeds?
As far as the original op's question about the car having Cruise Control Speed Limit system, I have no idea what this is referring to. There are 2 types of cruise controls offered in the US. The standard type that maintains your set speed but does not maintain any desired following distance to the car in front of you nor does it bring the car to a complete stop if the vehicle in front of is also stopping. The last 2 feature I just described is part of the Adaptive Cruise Control(ACC) system.
WellI thought my point was simple. In the brochure and indeed in 'my audi' the specs of my car tell me I have "Cruise control speed limit system"
Cruise control is just that, you set a speed and let off the accelerator understand that.
On my last car (BMW) was a limiter, hit the speed you wanted and press limit. Now in the mode you could hit the accelerator and it would not go beyond your set speed. This is an excellent system because when on the phone or what ever its easy to go to fast and cruise control leaves you with no control, of if set at 70 it does 70.
On the basis its just cruise control, why call it Cruise control speed limit system, thats muddy marketing for sure. Its just cruise control, there is no speed limit involved.
This is the description of the system from the UK brochure. No mention of Speed Limit at all. Also on Page 48 of the current US brochure the description of ACC makes no mention of speed limit either.
PCG
Adaptive cruise control (ACC) with Stop&Go function including pre-sense front. Automatic distance regulation, using radar sensors to maintain required distance by braking and accelerating. Four programs (distance 1 to distance 4) set via steering column controls of the cruise control system. Works at speeds between 0 and 155mph* and also includes Audi braking guard – a system which triggers a visual and acoustic alarm when it detects the risk of a rear end collision with the vehicle in front. In addition, the airbags are pre-conditioned if
a crash is sensed and the system is prepared to assist with the necessary braking force once the brake pedal is touched. Only available in combination with colour Driver's Information System (9Q8) and, on SE models, Bi-Xenon or all-LED lights (PXB/PX2). Not available in combination with manual transmission
PCG
