20x10.5 Vossen for A7 fit A6?
Old 10-12-2012, 11:36 AM
AlblineStar's Avatar
Default 20x10.5 Vossen for A7 fit A6?
does anyone know if the vossen application for the a7 will fit the c7 a6? theres a set for sale but dont want it to rub, and im on coil overs
Old 10-15-2012, 06:20 AM
HyperS4's Avatar
They do use the same offset and I would think it should be ok but damn thats a wide rim. For continued thoughts on the matter, for some reason the S7 uses 265's while the S6 uses 255's. Dont know why but maybe that car can handle the extra 10mm on either side. It is wider by a couple inches.
Old 10-15-2012, 08:16 AM
manishaudi's Avatar
Another Audi owner, jrAudi, I met during an Owners Meetup earlier this year changed the 255s with 265s on his A6.
Old 10-16-2012, 05:04 AM
day1yun's Avatar
I thought the A7 uses lower offset wheels... 20x8.5 ET32 vs ET45 on the A6
Old 10-16-2012, 05:09 AM
day1yun's Avatar
Got the actual A7 Offsets:
20x9" ET37
19x9" ET32
19x8.5" ET32
18x8.5" ET32
17x8" ET32
The A7 can handle a more aggressive offset than the A6. 10.5" wide is probably pushing it...I dont think it'll fit. I'm lowered on H&R sport springs and have had 20x9.5 ET35 in the rear with no issues. I'm currently on 20x8.5 ET25 in the front and 20x9 ET26 in the rear and have rubbing issues in the front when I am turning and hit a dip/bump in the road.
Old 10-16-2012, 07:37 PM
20x9" ET37
19x9" ET32
19x8.5" ET32
18x8.5" ET32
17x8" ET32
really? im running oem a7 20s w/ 15mm spacers lowered on coilovers and i have no rubbign in the front jus in the rear
Old 10-16-2012, 08:10 PM
manishaudi's Avatar
Which Coilovers did you get? I am looking to upgrade my suspension
Here is my thread: https://www.audiworld.com/forums/sho....php?t=2834695
Old 04-07-2014, 04:56 PM
cbnat's Avatar
Has anyone done this? I really like the more concave wheels that are 10.5 but need a square setup.
herc1996
Audi allroad
05-08-2018 07:25 AM
ernestolopez
10-28-2009 07:24 PM
AndrewF1
Wheels & Tires Discussion
11-28-2006 04:38 AM
AUDIMA
11-04-2003 06:34 AM
turbotom930
12-01-2002 06:14 PM
Quick Reply: 20x10.5 Vossen for A7 fit A6?
